does the first generation CL key have a chip
Old Aug 25, 2010 | 12:56 PM
P0401's Avatar
I have mentioned on here a few times that every now and then I have to turn my key 2 or 3 times before it actually kicks in the starter to crank the car and I remember my camaro doing this because of the VATS (Vehicle Anti Theft System) chip on the key getting messed up. My question is does the acura key have a chip in the black part of the key as well or is the whole switch that is getting ready to fail on me?
Old Aug 25, 2010 | 01:51 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The 98's and 99's do have a chipped key and immobilizer, there was also a recall on the ignition switches, you should check and see if your car was part of the recall
Old Aug 25, 2010 | 05:52 PM
P0401's Avatar
on acura.com this is what it says
Recalls
Concerned about safety? So is Acura. That's why My Acura provides up-to-date recall information about your vehicle. Because My Acura recall listings are based on your Acura's Vehicle Identification Number (VIN), they are specific to your vehicle.
(This is an electronic version of the letter that will be mailed to you. Please wait until you receive the actual letter before contacting your dealer.)
Your 1997 Acura is included in the 1997-99 CL/TL IGNITION SWITCH Campaign.
Description 1997-99 CL/TL IGNITION SWITCH Type Recall Customer Letter Status Fixed
so I guess the switch has already been fixed by the recall
Old Sep 9, 2010 | 04:12 PM
Trevor_CL's Avatar
I've heard of using a certain array of resistors to fool the system on GMs... maybe it could apply here too?
Old Sep 9, 2010 | 04:30 PM
P0401's Avatar
Yes all you have to do on VATS (Vehicle Anti Theft System) is take your key and measure with a volt meter the resistance of the black chip inside the key and then get a resistor with that same value and solder it into the VATS wires and it fools the switch into thinking its the correct key and allows it to crank
Old Oct 1, 2010 | 12:22 PM
codeman200's Avatar
8th Gear
98 and 99s do but they can be cloned, which saves the process of programming them and its cheaper.
Old Oct 10, 2010 | 10:33 PM
medium1's Avatar
Yes the key uses a chip. But your problem sound more like a starter/starter solenoid. The defective ignition problem wasn't a srarting problem it was a running problem after you release the key after it starts it would die unless you applied a little turning pressure on the key due to burnt contacts in the run position.
Old Oct 12, 2010 | 06:35 PM
P0401's Avatar
So the 97 does as well or just the 98-99? I am really confused now
Old Jan 16, 2011 | 02:44 PM
timeizmoney22's Avatar
Yesterday I went into the store, then came out hit the unlock button on the remote, hopped in and when I turned the key to start the car, everything went out. All power. I opened the hood and wiggled the battery cables then went back and the power was on again, but when I turned the key it did the same thing. So I wiggled the cables again, then locked and unlocked the car again w/remote and then it started no problem. Any suggestions?
Old Jan 18, 2011 | 12:11 AM
cyphon21's Avatar
Mine does the same, but not like the comment above. Everything is good for power, just when its really really cold it doesn't click in. When it does, it doesnt need mucht o start up at all. Such a weird thing.
Im going to rewire everything in the spring time since it's way too damn cold up here right now haha.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
LoneRonin
Sep 28, 2015 09:11 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
