Dimmer Relay Fuse Missing
Old Aug 14, 2007 | 03:58 PM
RyanCHICL's Avatar
#GOBULLS
I recently opened my fuse box under the hood and i noticed that the dimmer relay fuse is missing. I haven't noticed any problems with the car but I also don't know what this relay does. Can somebody please explain what the relay does and do I need to replace it?
Old Aug 14, 2007 | 10:58 PM
Nakamichi's Avatar
~[τΏτ]~
Does your high beams work?
Old Aug 14, 2007 | 11:18 PM
RyanCHICL's Avatar
#GOBULLS
yeah they work fine.
Old Aug 15, 2007 | 05:45 PM
Nakamichi's Avatar
~[τΏτ]~
To your original question, the Dimmer relay is used to allow the high beam circuitry to point to ground (PINs No 1 and No 2) when power is delivered on the trigger PINs (No 3 and No 5). In Canadian models with DRL, this also helps to determine the position of the combination switch. Just to be sure, I took out my dimmer relay and this did disable the high beam lights and indicator.
Can you verify the relay and/or take a picture? The dimmer in my fuse box has 5-PINs was green.
Old Aug 15, 2007 | 10:23 PM
RyanCHICL's Avatar
#GOBULLS
Yeah, I will double check tomorrow. This is for my 98 V6 Accord, but I don't think theres a difference between the 3.0 CL.
tsx_boy
Dec 13, 2019 08:33 PM
Acura604
20
Aug 5, 2017 12:55 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
ripit
Sep 26, 2015 06:19 PM
