Dimmer Relay Fuse Missing
#GOBULLS
I recently opened my fuse box under the hood and i noticed that the dimmer relay fuse is missing. I haven't noticed any problems with the car but I also don't know what this relay does. Can somebody please explain what the relay does and do I need to replace it?
To your original question, the Dimmer relay is used to allow the high beam circuitry to point to ground (PINs No 1 and No 2) when power is delivered on the trigger PINs (No 3 and No 5). In Canadian models with DRL, this also helps to determine the position of the combination switch. Just to be sure, I took out my dimmer relay and this did disable the high beam lights and indicator.
Can you verify the relay and/or take a picture? The dimmer in my fuse box has 5-PINs was green.
#GOBULLS
Acura604
20
08-05-2017 12:55 AM
ripit
09-26-2015 06:19 PM
