Click Click Click
Old Nov 28, 2007 | 11:24 AM
MetalKervin's Avatar
97 3.0 Premium
Click Click Click
When I start my car, I hear that about 80 times before it turns over. I have a 96 accord ex 5-speed. I thought perhaps someone on this site may have experienced this also. Any insight? I depress the clutch fully and turn the key, but it will just click, anywhere between 2 and 20 times before finally turning. What could be up? Thanks all.
Old Nov 28, 2007 | 11:29 AM
AznX TL's Avatar
where is....
starter or fuel pump on the way out?
Old Nov 28, 2007 | 11:41 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Your starter is toast
Old Nov 28, 2007 | 12:13 PM
Cocoa's Avatar
2600lb CL
Or a weak bettery that can't get enough power into the starter to crank the flywheel. You can get both tested.
Old Nov 28, 2007 | 12:34 PM
(Mid-Atlantic)
Yes, but usually if the battery is low you don't get the clicking, the clicking is the starter
Old Nov 28, 2007 | 12:48 PM
DaInFaMMuS1's Avatar
Yep, started is definitely done. I had the same exact thing happen to me, 2.3 5spd.
Old Nov 28, 2007 | 05:24 PM
Cocoa's Avatar
2600lb CL
Just 2 days ago my Lexus wouldn't start, and had the clicking sound over and over and over again while I attempted to start it. Jumped started it, and when I got home, I noticed my battery was completed dried when I took the 2 caps off. Put water in it, and recharged the battery. Been a charm ever since. I guess it just depends on how dead the battery is.
BUT, yes, if the battery is really low, you won't get the clicking sound.
Old Nov 29, 2007 | 04:34 PM
TexasHonda's Avatar
Starter can be repaired by replacing the copper solenoid contacts that wear out and cause the clicking (solenoid throws but contacts are worn so no starter motor engagement). Search my threads or look at sherco auto supply website for parts and pics.
good luck
Biggie_B
May 27, 2025 05:51 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
