CL trans fluid question
Old May 25, 2007 | 03:28 PM
Iagent's Avatar
How many here have a 3.0 trans that slips out of gear when coming to a stop during the warmup cycle? All is well once warmed up.
Also would like to add...Should I have used Honda transmission fluid instead of Mercon? Or is it just an evil plot for Honda to sell their own fluid?
Old May 25, 2007 | 04:33 PM
Nakamichi's Avatar
~[τΏτ]~
Mine does this every now and then on those super cold days. Only will happen once during a drive cycle. I used Honda in the past and currently Amsoil ATF. Nether seems to address the issue.
I would use Honda ATF vs Dexron-III Mercon. There are conflicting statements about this. My owner's manual says you can substitute Honda ATF using Dexron-III, while the service manual says using Dexron-III will prematurely wear our your transmission parts. Probably meant to say "temporarily substitute."
Old May 30, 2007 | 05:54 PM
Iagent's Avatar
Honda fluid! Honda Fluid!!!!!
I am definitely a believer now.
You wouldn't believe the difference the $5.70 per quart hyd fluid makes.
I urge anyone who is skeptical, and has these issues with their trans to try using the right stuff.
Old May 30, 2007 | 06:01 PM
Iagent's Avatar
I will probably change it again so that I am at 75% Honda oil.
IlliniAcura
Sep 19, 2015 09:31 PM
datadr
Sep 12, 2015 09:12 PM
nash3222
Sep 10, 2015 09:46 PM
jfman55
Sep 5, 2015 02:55 PM
