CL trans fluid question
How many here have a 3.0 trans that slips out of gear when coming to a stop during the warmup cycle? All is well once warmed up.
Also would like to add...Should I have used Honda transmission fluid instead of Mercon? Or is it just an evil plot for Honda to sell their own fluid?
~[τΏτ]~
Mine does this every now and then on those super cold days. Only will happen once during a drive cycle. I used Honda in the past and currently Amsoil ATF. Nether seems to address the issue.
I would use Honda ATF vs Dexron-III Mercon. There are conflicting statements about this. My owner's manual says you can substitute Honda ATF using Dexron-III, while the service manual says using Dexron-III will prematurely wear our your transmission parts. Probably meant to say "temporarily substitute."
Honda fluid! Honda Fluid!!!!!
I am definitely a believer now.
You wouldn't believe the difference the $5.70 per quart hyd fluid makes.
I urge anyone who is skeptical, and has these issues with their trans to try using the right stuff.
