CEL Help
CEL Help
I have a 99 3.0cl and I got my cel checked. 2 numbers came up
1- p0401-(EGR insufficient flow) what is the problem? I heard its something to do with clogging? Can I fix the problem myself? and does it need to be fix right away?
2- p1739(Automatic transaxle failure) what does this mean? and does it need to be fix right away?
If anybody know any information please post a reply
Thanks!
Thanks!
Thanks!
Thanks!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The EGR you can either remove and clean or get a new one on ebay for $50 and install it yourself, the transaxle is bad news, try going to a tranny shop and see what they'll charge to replace the axle
For the p0401
I called my local acura dealer to see if they can fix it and they said it will cost me around $1500.
Is that a reasonable price to fix this?
I heard it should cost only under 600 or less.
P1739 Possible causes
- Disconnected 3rd clutch pressure switch connector
- Short or open in 3rd cluch pressure switch wire
- Faulty 3rd clutch pressure switch
How much should the egr cleaning and new value cost?
and as for the p1739..is the problem actually a transaxle problem? or is it one of the problems that Nakamichi listed? the car seem to be running fine except its not as smooth as before, like when i push on gas the rpm rev up more often.
Originally Posted by AznX TL
p0401 is egr, i would clean out the egr ports. i took mine to the dealership, they took their jolly time to clean out the egr ports and every single pipe and put in a new egr valve.
