Catalytic converter !!!
Old May 28, 2015 | 09:59 AM
Red30cl99's Avatar
Check engine light just came on.. I scanned it and searched the code up. I need a new catalytic converter .. I'm a noob so someone please tell me if that's really important
Old May 29, 2015 | 06:53 PM
musiclevelz5's Avatar
It wont cause any problems other than less mpg and maybe a worse idle or slight drivability issues.
If left alone it can cause your O2 sensors to go bad especially the rear one that bolts in the cat.
I recommend getting a new oem unit asap when you can afford it.
Old May 29, 2015 | 11:48 PM
Red30cl99's Avatar
Appreciate all the help !!
Old Aug 4, 2015 | 12:53 AM
ibGTV's Avatar
I got the same code. It was not the cat or the o2 sensor. You should try cleaning the egr first then see if code clears.
Aug 15, 2019 12:58 PM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Rcelestino93
Sep 23, 2015 10:01 PM
jpm3071
NY/NJ
Sep 7, 2015 08:25 AM
