both low beam headlamps out
Old Feb 15, 2007 | 12:08 PM
kabiria's Avatar
both low beam headlamps out, quarts are OK
Acura CL 3.0 1997 both highbeam work fine,
is there a separate relay for low beam? If so, where is it located.
any other ideas?
Kabiria
Old Feb 15, 2007 | 02:06 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I would check your fuses and bulbs before you start messing with relays
Old Feb 15, 2007 | 08:36 PM
TexasHonda's Avatar
Power feed is same for both hi and lo beams, so fuse problem is unlikely.
Dimmer relay seems likely to be the problem, but it could be the dimmer switch on the column. Dimmer relay is in the underhood fuse box on other models.
good luck
08KBP_VA
Oct 22, 2019 01:55 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
rockyboy
Sep 29, 2015 12:05 AM
ceb
ILX
Sep 27, 2015 10:56 AM
