Blaaahhh busted radiator stop leak
Old Jan 26, 2012 | 06:35 PM
on1wheel01's Avatar
Welp got a hole near the top of rad in front gonna try some bars stop leak anybody have good exp with it? If it doesn't work guess weld or replace time
Old Jan 26, 2012 | 11:47 PM
bRunCL's Avatar
id stay away from that stuff like the plague unless you're gonna dump the car or the motor in the near future. once that stuff gets in your cooling system i cant see it all ever coming out. just my
Old Jan 26, 2012 | 11:57 PM
ohsixMTee's Avatar
Early Shifter
You're better off just carrying a gallon or two of water with you, that crap will clog your system and then you will have 2 issues to deal with instead of just one.
Old Jan 27, 2012 | 08:08 AM
timeizmoney22's Avatar
Just replace! Farely easy and like 98 bucks for a new one nowadays unless you insist on an oem one. I've had one from advance auto in for about 6 months now and it seems fine.
Old Jan 27, 2012 | 08:21 AM
EL_PIC's Avatar
Rich and Famous
Weld is best way. Replace can be $$.
Advise no on Stop Leak.
Old Jan 27, 2012 | 08:57 AM
Project_CLean's Avatar
MMkay.
Replacements are relatively cheap; check local auto parts
Old Jan 27, 2012 | 09:06 AM
DaInFaMMuS1's Avatar
Just do yourself the favor and replace it, the stop leak is a bad idea.
Old Jan 27, 2012 | 12:17 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The stop leak is a bandaid fix I would replace ASAP
Old Jan 27, 2012 | 12:29 PM
on1wheel01's Avatar
ok guys thanx. I may not use it. I found the crack may try to have it welded or jb weld n see if it works done it before with good results lol
Old Jan 27, 2012 | 04:18 PM
I think this is one of the cases where the "shortcut" may be the long way, if it's cracking now its only a matter of time till it gives out at another point don't u think?
Old Jan 28, 2012 | 09:32 PM
SupraManAG's Avatar
One custom CL
You can get a rad real cheap and replacing is real easy. Dont use that crap
Old Feb 2, 2012 | 11:07 AM
Tehvine's Avatar
6spd FTW
Replacing the rad was the first thing I had to do back when I bought my CL. It was like $70 at advance auto parts.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
