Battery Drain overnight ???
Old Jun 4, 2013 | 10:04 AM
BlackNsx24's Avatar
3rd Gear
Angry Battery Drain overnight ???
I am looking for some help into a 1998 2.3 CL I just bought. I am having a problem with the battery draining overnight. I thought it might be the battery so I had it tested and it was bad, So I replaced it with an aftermarket one. It then started so I drove it up and had the alternator tested and it is OK. So I thought my problem might be gone, next morning go out and the battery dead as a door nail, .19 volts so I charged it back up all day. Started testing the amps while pulling fuses and couldnt get it to drop when one was pulled. So I pulled all the under hood fuses and left the car over night, next morning DEAD!!!! So recharged it yesterday and decided to pull all the under dash fuses, this morning DEAD again. What could be happening? I am looking to you guys for help......
Old Jun 4, 2013 | 10:18 AM
BlackNsx24's Avatar
3rd Gear
So I was searching thru some old post on battery drain and one mention:
"Check first that your ground wire is fully connected, not rusted . You maybe finding you may have a bad ground or cable that is discharging the battery.
Looking at my ground that goes down the tranny is major corroded, could a faulty ground cause a battery drain?????
Old Jun 4, 2013 | 09:30 PM
mattastick's Avatar
Yes, a faulty ground can cause a battery drain.
Old Jun 5, 2013 | 12:00 AM
BlackNsx24's Avatar
3rd Gear
Sounds like I will be changing the ground and terminal out,
Thanks for the info. Can anyone else think of anything else to look for?
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
