Aftermarket Head Uint Keeps Shutting off
Atown PA
About a year ago I had a flipout Phase Linear head unit installed from Circuit City(Bad Idea) and I've always had a problem with it shutting off when I cranked the volume up pretty high. I figured this had something to do with my stock Bose Speakers. Then I installed all new speakers, sub, and an amp and the damn thing still shuts off. Not really an expert on adio so does anyone have any ideas as to where I should start troubleshooting?
6spd FTW
It may be a shitty ground, I have had to reground radios hooked up via the circuit shitty smart harnesses. But like he said, go over the connections to be sure. Also head out to the trunk and look behind where the jack goes and see if wiring was cut / looped etc.
How high are we talking volume-wise when it cuts out? If you're trying to turn the head unit up past 60% of it's maximum volume potential, that's your problem. The head unit is going into protect, just like mach30 said...
less n00bin more g00glin
+1...something is drawing too much juice from the system
