Acura CL 1998 does not start
Old Sep 2, 2012 | 06:09 PM
jigdesai92's Avatar
5th Gear
Hi I have a 1998 Acura Cl 2.3 Auto and it doesnt start. I went to fill gas and afterwards it never started. The battery is ok because my lights and stereo work just fine. I made sure the car was in park and tried starting it in nuetral also, but no luck. What could it possibly be? please help thank you!
Old Sep 2, 2012 | 08:16 PM
youmadeyou's Avatar
I have the Same year and car... Check out some Research on The fuel pump Relay. I have found this to be a common problem .. my car is also having this problem started today.
But could also be a number of other things .. help this helps.
Old Sep 2, 2012 | 08:30 PM
asianspec's Avatar
well before even looking into the fuel, does it click when you try to start? check distributor and starter? Our cars have a ignition problem also which there is a recall for the cars.
btw this if the 2nd gen forums. try posting on the first gens.
Old Sep 2, 2012 | 09:25 PM
jigdesai92's Avatar
5th Gear
ok thank for the help guys i will check out my car again and repost this thread in the right spot lol
Old Sep 4, 2012 | 12:04 AM
youmadeyou's Avatar
The is a couple of threads on here .. on that subject .. read a few and see it your stores relate thats how i found out it was my Fuel Relay ..
Old Oct 6, 2012 | 04:18 PM
youmadeyou's Avatar
Damn it.. I must have jinx myself because now Mine wont start... it's cranking and getting fuel but not starting .. so anyone have a Idea to tell if its the Fuel relay , Ignition, or Distributor ? im guessing its one of these 3.
Old Aug 9, 2013 | 04:24 PM
Mark K. Wells's Avatar
7th Gear
I found a Youtube video which shows how to remove the main fuel relay and by taking a flash pic you can tell if its the relay, bad solder joints which usually act up during hot weather. Hope this helps. New so not sure about posting a link to you tube, just type in year, make, and model, main relay and you should find it easy enough.
saberlove
Mar 11, 2021 09:29 AM
Allen_442
Sep 8, 2015 06:01 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
