AC stuck in ON position??
Old Jul 20, 2011 | 09:50 AM
97'CL2.2's Avatar
i was driving yesterday with the AC on for an extended period of time. I noticed a strange PVC/plastic smell so i turned off my AC...however with the AC in the "OFF" position it was still blowing as cold as it was with it in the "ON" position. also i usually notice a slight drop in revs at idle and decreased performance when i turn the AC from off to on...but i am not noticing that now. all the buttons on my temp control work perfectly, it just seems as if the AC isnt disengaging...
Old Jul 20, 2011 | 10:12 AM
saiko_cl_duck's Avatar
can you adjust your fan speed at all?
Old Jul 20, 2011 | 02:05 PM
97'CL2.2's Avatar
yea i can...every button in the temp control area functions normally, the car simply isnt behaving as it normally does when i turn AC on/off (temp feels the same and revs are uniform reguardless of AC on or off).
Old Jul 20, 2011 | 07:06 PM
97'CL2.2's Avatar
AC is definatly stuck in the on position. i know this because when i looked under the hood my low line was covered in frost when the AC was off. i dont wana blow up my compressor...any ideas on how to fix this?
Old Jul 21, 2011 | 07:24 AM
check the relays first. The blower motor resistor could be on it's way out. Mine was jacked up, and I couldn't turn the A/C off, then it wouldn't come on period, then a couple days later I couldn't adjust fan speed.
For now, if you don't want to run A/C, just pull the fuse.
Old Jul 21, 2011 | 07:27 AM
check out part number 7
http://acuraautomotiveparts.org/acur...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Old Jul 21, 2011 | 04:01 PM
97'CL2.2's Avatar
Thanks for the info. I noticed that only one fan comes on when I turn the ac on in the cabin.however even when I turn It off in the cabin the fan stays on. So basically its on all the time and the fan closest to the compressor won't turn on at all
Old Jul 27, 2011 | 04:51 PM
97'CL2.2's Avatar
anyone every heard of the auto AC switch assy or the auto AC computer assy going bad in our cars?(number 3 and 2 in this picture)
https://www.oemacuraparts.com/index....ATER%20CONTROL
bc this is what the shop i took my CL to is trying to feed me...they say they diagnosed my problem as one of these two (the most expensive pieces big surprise) and i think they are full of shit. need some input here....
Old Jul 27, 2011 | 07:49 PM
Try this, sounds like they are part swapping for no reason.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
