AC not working??? HELP
Old Aug 7, 2009 | 08:20 PM
JDM97CL's Avatar
My AC just stopped working out of no where. I have no clue what it is and i was wondering if anybody has any suggestions on what it may be. I was told i might need freeze on but idk.
Old Aug 7, 2009 | 08:58 PM
Tehvine's Avatar
6spd FTW
Is the compressor kicking on? Should be noticeable when it does kick on at idle.
Old Aug 10, 2009 | 07:12 PM
JDM97CL's Avatar
nope it doesnt
Old Aug 11, 2009 | 12:10 AM
acura_honda_30cl's Avatar
i have a question my a/c work and it blows cold air but not as that cold...it blows like the fan is just on? do i just need to put freion on it....
Old Aug 11, 2009 | 10:05 PM
JDM97CL's Avatar
Yup.
Old Aug 18, 2009 | 12:46 PM
JDM97CL's Avatar
so its the compressor???
Old Aug 18, 2009 | 09:48 PM
WineRed2.2CL's Avatar
Old School Ridin Clean
yeah if its not blowing any air out
Old Aug 24, 2009 | 03:59 PM
JDM97CL's Avatar
its blowing air just not cold
Old Aug 24, 2009 | 04:53 PM
YtseJammer's Avatar
Low and Slow
Will it blow cold if you rev or floor the gas, or does it always blow hot? I'd put more freon in it and check for leaks. If you try to run the a/c for too long like this it may end up frying your compressor like it did with mine.
Old Aug 24, 2009 | 07:58 PM
JDM97CL's Avatar
its always hot even if i rev it. But my car was in a accident before and i donr kno if it was fixed or not. because it did work, its jus not cold
Old Sep 4, 2009 | 07:49 AM
khmerpride's Avatar
Did you figure out the a/c? My car a/c isn't working as well.
Old Sep 4, 2009 | 10:05 AM
JDM97CL's Avatar
Nah i didnt i guess nobody knos what it is.!
Old Sep 4, 2009 | 05:01 PM
khmerpride's Avatar
Ah, well if you ever get it diagnosed by a shop, let me know how it goes. I need to get my a/c checked too.
Old Sep 4, 2009 | 06:18 PM
JDM97CL's Avatar
ight man no dought but its probly not guna b for awhile cuz its about to be winter for me so... but ill still find it out and ill let you kno.
Old Sep 4, 2009 | 10:34 PM
khmerpride's Avatar
Lol, yeah, I don't plan on fixing mine till spring too. My a/c compressor still turns on and works, but it has a leak somewhere, haven't gotten it checked out yet. I just hope it's not a major component broken somewhere and that it's just a hose or something leaking.
Old Sep 7, 2009 | 12:31 AM
JDM97CL's Avatar
see ur lucky lol i cant here mine turn on so i dont kno whats going on
Old Sep 7, 2009 | 12:30 PM
if it blows air at least. Refill it with r 34 refrigerant, But buy the whole kit with a gauge that tells you if your low on freeze to high or got a leak.
Good luck
Old Sep 7, 2009 | 12:43 PM
JDM97CL's Avatar
thanks man
Old Sep 10, 2009 | 10:09 PM
acurahb's Avatar
Try connecting 12 volts to wire on compressor- if clutch on compressor kicks on-check the relays hanging off radiator. If it doesn't it's probably the compressor.
Old Jul 28, 2010 | 02:27 AM
arsouders's Avatar
Master of the Commode
Any resolution ever come of either situation?
Old Aug 2, 2010 | 10:59 AM
shadow1185's Avatar
6th Gear
Thanks for the information WineRed2.2CL. My A/C blows cool air not cold. The shop wanted $175 to charge it. Thinking of getting the kit and doing it myself!
Old Aug 17, 2010 | 07:56 PM
littlekoreanboi's Avatar
6th Gear
somethings wrong with my a/c. it works perfectly fine with cold air but its leaking cold water by there the passengers foot would go... while driving, when i turn hard it leaks water inside as well. can anyone tell me how to fix this? i've already invested $500 on the a/c... its starting to piss me off. :p
Old Aug 18, 2010 | 10:37 AM
sickcl480's Avatar
Your evaporator core is leaking either because the tube that drains the water out of the car has fallen off or because the evaporator is cracked. Basically it’s a big black box you can see if you look under the passenger dash that should have a tube coming off the front and routes the condensation out of the cabin and drains onto the road. Hopefully that helps.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
