abs rear left then rear right
Old 10-15-2011 | 02:39 PM
rondugo's Avatar
3rd Gear
I used the paper clip to flash the abs codes 1997 2.2 CL and got 4-8 LR sensor, replaced and immediately got code 4-4 RR sensor. The 4-4 code did not flash before I replaced the LR sensor. Has anyone seen this before.
OHM reading on the old LR sensor was 27 M ohms.
I don't want to chase this with new sensors unless I have to, they are a little expensive.
Old 10-17-2011 | 12:09 PM
Hullka's Avatar
5th Gear
I had the same problem, ABS light came on, found out it was my back left ABS sensor. Went ahead and replaced it and almost immediately after replacing the left one the right rear sensor went bad. Unfortunately I didnt do alot of research into finding out why they went bad, I figured they were so old that it was time to replace them.
rondugo (10-18-2011)
Old 10-18-2011 | 04:47 PM
rondugo's Avatar
3rd Gear
Thanks I will get the r- rear sensor
Old 10-21-2011 | 03:48 PM
udee's Avatar
98 3.0CL
It just cause it get old, I have replaced both rears one after another! Haven't had any abs issue afterwards! Good Luck - oemacura is where I got sensor from!
Old 10-29-2011 | 03:00 PM
rondugo's Avatar
3rd Gear
changed the r- rear sensor nad the abs works fine now. Thank you for your help.
mada51589
05-03-2022 08:54 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Ny1718
09-11-2015 09:21 AM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: abs rear left then rear right
