ABS Light as a speed sensor?
I got a problem recently that when my car go over 85 the ABS light start to turn on and stay there. After you turn off the car and on again, the ABS light will be off. For a few more test with myself I found that if the car was on a down slope run that gone over 85 or even 90 the ABS didn't come on. But if you are accelerating on a flat or slightly uphill highway to go over 85, the ABS light will come on. I have no idea what is going on there? Can anyone help? My car is a 97 CL 2.2
Def sounds like a wheel speed sensor, you have 4, and if one goes bad, it triggers the ABS light, or it could be reading chips or dirt on the axle too, I've had both problems. I've replaced 3 now, and an axle
Originally Posted by TiggerCarman
Thanks, it could be the axle than, because it happen right after I have changed the passenger side axle.
thanks for the info....
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
