ABS light and right turn signal fuse issue
'97 2.2 CL
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I just bought my '97 2.2CL and it has some issues. My ABS Indicator light on the dash was lit, and the guy I bought it from said he messed with some of the fuses. The 7.5 amp "heated mirror" fuse under the dash was missing so I replaced it. To my delight the ABS light went out... only problem is now the right turn signal is stuck on. If I pull the fuse back out, the ABS light comes back on and the turn signal works properly, WTF! I hope someone can help me out. This is just one of the many annoyances with this car. Thanks.
~[τΏτ]~
The "heated mirror" fuse also supplies power to the ABS module. ABS light will always illuminate since the ABS module will fail the self-test w/o power. If your front and rear right turn signals are on, that circuit is most likely providing power to the right turn signal light.
I would ask the previous owner what he/she did and reverse the process. If that doesn't work, from the under-dash fuse box, locate the turn signal/hazard relay. It should be located in the upper-left of the fuse panel. Follow the GRN/YEL wire from there and ensure there is nothing tapping into it.
Lastly drop kick the guy who did this. Good luck.
mada51589
05-03-2022 08:54 PM
drewdeezy03
09-03-2015 08:04 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
