ABS light
Old Sep 15, 2007 | 03:53 PM
JStoops's Avatar
ABS light
hey i was driving on 84 earlier today and my ABS light went on and stayed on... any clue on what could of caused this? i havent driven the car hard in months and i wasn't even breaking when it went on.
Old Sep 15, 2007 | 04:04 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Wheel speed sensor, there are 4 of em, and they go bad quite a bit. That is the most likely cause I've replaced 3 of the 4 on my car alreay.
Old Sep 15, 2007 | 08:28 PM
Danil ACE's Avatar
Sounders FC
Check your fluid level. Mine was turning on along with the BRAKE light when I had a leak in the rear caliper.
Old Sep 19, 2007 | 12:18 PM
<syphers>'s Avatar
i believe its actually a seal inside the modulater that goes bad. mine goes out all the time no big deal. and what 84 you talkin about, the one in CT.
Old Sep 19, 2007 | 12:50 PM
(Mid-Atlantic)
Could def be your brake fluid as well, try topping off the brake fluid and see what that does
Old Sep 19, 2007 | 01:50 PM
saiko_cl_duck's Avatar
moved
Old Sep 20, 2007 | 11:04 AM
JStoops's Avatar
How does one go about changing this seal? Also, how would i be able to tell which, if any, of the sensors are bad?
And yea it's 84 in CT i go to UCONN Storrs
Old Sep 22, 2007 | 11:32 AM
JStoops's Avatar
BuMp.... My car is gunna be up on jack stands with all 4 wheels off tomorrow so if i could figure out how to do this it would be great.
Old Sep 22, 2007 | 09:21 PM
TexasHonda's Avatar
If you have a 2.2CL, short the service check connector (blue 2 wire connector under glove box) and read the codes flashed by the ABS light. There is a 2-sec initial flash, followed by code flashes. They are all short flashes w/ a 1-sec pause between 1st and 2nd digit of code (example ffff-P-ffff = code 4-4). Get codes and perhaps I can help.
A good reference manual for ABS can be obtained by downloaded 94-97 Honda Accord Shop Manual from hondahookup.com. The ABS system on the 94-97 Accords is same as 2.2CL Acuras.
good luck
good luck
Old Sep 25, 2007 | 07:21 PM
<syphers>'s Avatar
yo jstoops we shoudl get an ack meet goin sometime. i'm down near new britain. anyway you cant change the seal you need to change out the whole modulater woot. i saw a used one on ebay for about 70 bux i dont kno how much a new one would go for. prolly a pretty penny.
Old Oct 4, 2007 | 04:01 PM
JStoops's Avatar
ok so i brought the car to a local shop near my school recommended by all the members of the UCONN car club but they said they couldn't communicate with my ABS computer.
however, i'm about 90% sure its an ABS sensor. i'm gunna just pull it out of the shop and try to figure it out myself. however, i have to clue what the ABS sensor looks like. can anyone put up a picture of what it looks like on our cars? front and rear would be awesome.
thanks....
and <Syphers> you should come to the UCONN Car Club show it's next weekend (13th with a raindate of 14th) its only about 35min from you. check the events thread to get more info. theres a couple of AZ members comin
Old Oct 5, 2007 | 08:11 AM
TexasHonda's Avatar
There are many possible faults in an ABS system. While wheel sensor is a good possibility, it is far from certain and an OEM replacement is expensive. If you extract the ABS code as suggested above, it will go a long way towards narrowing the possible faults.
good luck
Old Oct 6, 2007 | 10:44 AM
JStoops's Avatar
how do you short the ABS service connector?
Old Oct 6, 2007 | 03:18 PM
TexasHonda's Avatar
http://www.troublecodes.net/acura/
This is for the DTC's, however the same service check connector is shorted for ABS codes, however the codes are flashed on the ABS light as described above.
Get the flash code and I should be able to provide some guidance on your likely problem.
good luck
Old Oct 6, 2007 | 04:16 PM
JStoops's Avatar
still not understanding how to short it.... i mean from what i read on that site, i just turn the key to the on position?
Old Oct 7, 2007 | 06:57 AM
TexasHonda's Avatar
Scroll down to yourmodel and use item 2) MIL method. Again, the flashes are on the ABS.
good luck
Old Oct 7, 2007 | 10:50 AM
JStoops's Avatar
# To use MIL, proceed as follows:
1. Connect SCS service connector special tool No. 07PAZ-0010100, or equivalent, to service check connector located under passenger’s side of dash.
2. Turn ignition On.
1. MIL will indicate DTC(s) by number of flashes.
i don't have that tool
Old Oct 7, 2007 | 05:36 PM
TexasHonda's Avatar
A paper clip or other short piece of wire will substitute. It is only necessary to short the two connector points.
good luck
Old Oct 15, 2007 | 02:13 PM
gregscotch's Avatar
I have the same problem. In my case the ABS sensor is defective (some rust) and according to the Acura dealer must be replaced in order for the ABS system to work. It is expensive to repair( $300. to $400. per wheel!).
I decided to ignor it since the breaks work fine, just dont have antilocking capabilities any more.
I'm trying to find out how to get rid of the dash light that stays on until the ANs system is working.
Old Oct 16, 2007 | 11:45 AM
<syphers>'s Avatar
yea i'm trying to figure that out too I'm not too concerned about not having ABS but that light is annoying I'm just gonna take my dash apart and see if i can take the bulb out. I'm pretty sure theres a DIY somewhere about the dash removal. I used it to put in my LED's. I'll keep you updated.
Old Oct 16, 2007 | 06:27 PM
TexasHonda's Avatar
I would suggest removing and cleaning the wheel sensor (s). The spoked hub (called tone wheel for some reason) underneath the sensor is cleaned in place by stuffing a rag into the hole where the sensor was pulled and turning the wheel. The sensor and cogs can become grease-covered and cause a wheel sensor fault. Corrosion might be an issue, but I'm skeptical.
good luck
Old Aug 22, 2008 | 06:41 PM
JStoops's Avatar
can someone link or take a pic of the thing i'm supposed to be shorting? i can't find it for the life of me. it's driving me fucking nuts. i have a '99 2.3CL not sure if that makes a difference on its location but i cant find anything that remotely looks like i can connect something to it
Old Aug 23, 2008 | 08:38 AM
TexasHonda's Avatar
http://www.troublecodes.net/honda/
Above link depicts the connector. It's usually plugged into a dummy female holder and must be released by pinching and removing.
It is possible that Acura removed this connector by 99, but I don't know for sure. I think at some point Honda removed this backup system of accessing trouble codes and went w/ OBD2 alone which requires a separate sytem. ABS may require a special interrogator to access codes, but some 98 Acuras (98 2.5TL) did use this manual ABS code system, so there's a chance yours does also.
good luck
Old Aug 23, 2008 | 10:26 AM
purple3.0haze's Avatar
The same thing happened to me on 84 going on my way into Rye, NY i was driving and it just popped on. I ignored it until on my way home from rye on the taconic, i had no brakes at all. I mean NO BRAKES, i couldn't pump them up nothing it just dropped to the floor. Turns out i put a faulty rebuilt caliper on and it was squirting fluid out every time i hit the brakes. needless to say i used the ebrake and engine braking to exit the highway and made it home ok. But i did find this strange brown streak in my underwear when i got home. Scary
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
