99 CL 2.3 5 Spd -- ABS Light...Ughh
I am getting an occasional solid ABS light right @ key on. Sometimes if I restrart without moving the car it goes away.
I used http://home.insightbb.com/~niedejb/ site info to pull the codes and came up with a 15, but don't see it in the list. Just to make sure I wasn't missing anything I recorded the ABS flash sequence @ http://home.comcast.net/~da-home-boy/MOV02858.MPG.
Any help would be appreciated...othewise Autozone here I come.
Thanks,
Detroit Chris
Thanks,
Detroit Chris
I had that on my 2.2cl. It was just a bad abs pump (honda is notorious for bad abs pumps). When they go bad they usually get stuck on and it throws the light on. I just had the abs pump turned off and had the light turned off when I got my cv-axles replaced. Now I just need to find the money for a new pump.
Ever since I got my car (97' 3.0) back from the shop (replaced CV-Axles) I've been lighting up like an X-mas Tree. The [brake] light will sometimes come on, and usaully following the [brake] light, the [ABS] light will come on. I called my shop and told them, that the lights seemed to come on when the car was in motion (goin around corners). So they told me to check the "brake fluid" to see if it was low. It seemed to be and I topped it off. The lights didnt come back on for a few days, and now, ....well now the lights (both [brake] and [ABS] ) are stayin on. I'm now starting to think that im losing brake pressure when I go to apply the brakes.....
Does this make any sence to anyone??? I need to get the car back in the shop, but I donno what the hell could be wrong with it now...!?!.... Can anyone help?
Thanks! - CJ
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
DerrickW
Nov 15, 2015 05:52 PM
