99 3.0 CL external window screw?
Old Jul 29, 2013 | 04:44 PM
12centuries's Avatar
So my trusty 99 CL 3.0 is returning from the mechanic (timing belt, water pump, tie rod ends, wheel hub & bearing replacement, etc) and all should be well assuming the transmission doesn't fail any time soon. I'm at 220,000 miles, hoping for 300,000.
Here's my question:
The driver's side window has a rounded-head screw that holds the top-right of the window to the track that moves it up and down (when looking at the driver's side window from the outside).
That screw has gone missing, so the window sticks out when you put it up unless you open the door and hold the window against the car until it goes up enough to get under the rubber seal.
I have not been able to even find a NAME for this part, much less where to get it. Any ideas?
I can post pics if requested.
Old Jul 29, 2013 | 08:45 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Contact Tim at acuraoemparts.com
Old Aug 5, 2013 | 03:49 AM
J-NACE's Avatar
Just had to replace this on my CL. Before I replaced it I found a small bolt that would fit in there to keep the piece from falling down in the door. the bolt did fine just couldn't roll with window down all the way. Sorry but I for get what its called.
Old Apr 11, 2015 | 06:34 PM
acuraoemparts.com looks good, but the shipping seems like a lot for a few spare parts. J-NACE, do you know what the specs are for the screw? Thanks
Old Apr 21, 2015 | 09:07 AM
01acls's Avatar
Pic plz
Old Apr 21, 2015 | 11:50 AM
01acls's Avatar
Ahh, chances are that screw is sitting at the bottom of your door. If it's loose you can shake the door and hear it... or not. But where can it go? It's in there some where.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
