99 2.3 CL trans cooling lines question.
Old Apr 15, 2010 | 09:32 PM
mgroeger's Avatar
4th Gear
I have a 1999 2.3 CL automatic.
my question is when you are looking into the engine compartment the trans is on your left. from the top of the trans 2 lines come down and run into the bottom of the radiator (the trans cooling lines).
which one of these is the return line that takes the cooled fluid back up into the trans from the radiator? the reason i ask is i would like to put an inline filter on it since in their infinite wisdom acura stuck the trans filter up in the trans to where you need to drop the trans to clean it.
i was told to put the inline filter on the return line. why does it matter which line you put the filter on?
thanks,
mike
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
dirleton
Sep 29, 2015 08:26 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
mellsonnj
Sep 24, 2015 04:42 PM
