97 CL 3.0 - ABS question
Old Nov 19, 2012 | 09:00 AM
mabmab12345's Avatar
8th Gear
Hello. I am getting the following ABS codes:
1-3 Is a high pressure leak
4-4 Circuit of right hand rear wheel speed sensor
Does anyone know/have an opinion if one could be causing the other; or are they two totally separate issues.
Also, I see how to replace the sensor if need be, but what about the high pressure leak? Any thoughts on what needs replaced there?
thanks.
Old Mar 4, 2013 | 10:20 PM
AlexanderAcura's Avatar
5th Gear
You can most of the time turn your car off then immediately back on to turn this off, you could also ask to have your computer reset and remove the codes, if they come back it could be a cut in one of your hoses, or an 02 sensor.
Old Mar 5, 2013 | 01:44 AM
Myxomatosis's Avatar
or you can just ditch the ABS, like I did. It's still in the car but I just disabled the ABS light. I hate ABS anyway and the older the car gets the more you'll have to replace and yes you can pass inspection.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
navtool.com
Sep 25, 2015 05:15 PM
