97 3.0 Transmission OD question ?
Old 01-15-2006, 05:36 AM
bossanova5's Avatar
I changed the transmission fluid on my 97 3.0 a week and a half ago.Now I'm noticing on the freeway that the engine is turning close to three thousand RPM at 70 miles per hour.It used to turn around 2500.The transmission shifts fine and doesn't seem to be slipping.
How fast does your engine turn at 70 in OD?
I'm thinking I shouldn't have changed the fluid now because the transmission was perfect be I touched it.
Old 01-16-2006, 10:51 PM
5th Gear
clayto's Avatar
I know on higher milage cars not to touch the transmission fluids because they seem to get use to whats in it. Now if the only thing that changed is the R.P.M. at which it is shifting then it doesn't sound like its a problem. If it is not slipping it, you are in the clear. Good luck
Old 01-17-2006, 07:05 AM
knothd's Avatar
Did u go back with factory tranny fluid?
Yikes
05-03-2021 04:29 PM
pstomps
02-20-2017 03:29 AM
BoricuaTL
04-08-2016 01:08 PM
datadr
09-12-2015 09:12 PM
Mikehxbx
08-31-2015 10:17 PM
Quick Reply: 97 3.0 Transmission OD question ?
