97 3.0 how can you tell/test the water pump
Old 10-19-2015, 11:23 AM
yung.nate1st.gen.cl's Avatar
Yo my 97 3.0 has been gobbling up coolant but Imy not seeing any leaks on the floor etc and there isn't any water in my motor oil or tranny I already got a new t-Stat and bought a radiator wen I got the car in March. I wanna try and fix the problem already invested enough in the dammed thing. Lol rebuilt tranny right wen I got it n plus it's my baby. Im hoping it's not a blown head gasket. What else can I look for?? And if it's blown I want to know what engine I can upgrade to?? -bigger is better- lol thanks for the help guys
Old 11-10-2015, 10:37 AM
pstomps's Avatar
Someone correct me if I'm wrong, but you should be seeing oil in the coolant (or vice versa?) if you have a blown head gasket. You can get a UV dye at the hardware store that shows up easily with a UV flashlight/blacklight. That would help you confirm whether or not there is a leak, even if it's very slow. Could be a very slow leak. Do you smell coolant at all in the car or under the hood? Also look up at the hood liner and see if there are any traces of it there from splattering.
I mean, it's gotta be going somewhere, so if it's not on the ground, it's somewhere else in your car. I'd start with the UV dye, make sure the bleeder valve is tight, and maybe try another radiator cap. Leave the dye in for a few days to a couple weeks, or long enough that you notice a drop in the coolant level.
Old 11-10-2015, 12:15 PM
Dude I'm thinking it might be leaking through my exhaust but it isn't smoking though. My t-guage goes a little crazy wen I drive it at low rims until it gets up to 3500 or so then it goes down a bit it's got me stumped
Old 11-10-2015, 03:13 PM
01acls's Avatar
Replace the rad cap.
A blown head gasket will have white steam coming out of the exhaust and kinda wet too. Also look for a whitish/grey sludge on the oil cap.
Drain the oil. Water/coolant and oil will separate so scoop some up in a clear container and look at it.
Old 11-10-2015, 03:50 PM
No sludge I've looked I haven't seen any water in the oil either that's why I'm stuck
Old 11-10-2015, 04:13 PM
01acls's Avatar
Ok then no use guessing. Simply do a cooling system pressure test or vacuum test.
Old 11-12-2015, 01:31 PM
I'm gonna try the UV dye see how that goes.
I know these motors warp under excessive heat faster than regular motors. But I just wanna take the steps before I just go get another motor
Doc.Hollow
07-05-2020 01:38 AM
OculiAquilae
11-13-2015 11:44 AM
Damir1987
11-11-2015 02:31 PM
trailmix211
10-29-2015 09:09 PM
Bob Chadwick
10-19-2015 10:06 AM
Quick Reply: 97 3.0 how can you tell/test the water pump
