1st post a dandy
Old Oct 16, 2007 | 11:21 PM
Cl_tildeath's Avatar
7th Gear
Lightbulb 1st post a dandy
Ok here it goes
my 97 2.2 cl has 189k and has had the v.s.s (variable speed sensor) disconnected for about 6 months so i've been w/o a speedometer and I'm guesssing in open loop due to piss poor performance. A few days ago while I was driving my Tach went completely dead but the car was still running....got home & turned the car off....won't turn back on, windows don't roll up, clock doesn't work,but the locks,alarm,cooling fan etc. are working.....all I get w/ key in ignition on is a battery light on the dash and no click but the car does run if I jump the stater.... I've tried everything (I can think of) fuses are good, battery tested good.
PLEEEASE HELP! any advice or suggestions I'm stummped
Old Oct 16, 2007 | 11:59 PM
AznX TL's Avatar
where is....
test the alternator?
Old Oct 17, 2007 | 12:06 AM
AznX TL's Avatar
where is....
im pretty sure its your battery.
Old Oct 17, 2007 | 12:31 AM
asianspec's Avatar
ignition problem maybe? there is a recall on that for our cars
Old Oct 17, 2007 | 07:25 AM
TexasHonda's Avatar
I agree you should make sure you have a good battery first.
A new VSS is < $25 bucks on ebay and takes 1/2 hr to install. No reason to go w/o a VSS (Vehicle Speed Sensor).
Loss of tach suggests you could have a coil failure, but loss of power from keyswitch or battery would have similar effect. Get a good battery and check your alternator is charging w/ a voltment (should be 13-14 volts at least.
good luck
Old Oct 17, 2007 | 08:45 AM
young03's Avatar
its JDM yo!!!!!!!!
sounds like its an ignition problem
Old Oct 17, 2007 | 11:31 AM
7th Gear
Thanks for the suggestions. I've tested the -alternator (14.6 volts)
-battery (550cca, 12.65 static)
The car still drives so I don't think it is the ignition system.......or is it? I do have an aftermarket msd cap which called for the removal of my stock coil which I replaced with an aftermarket blaster coil (msd) this is run by a msd ignitionPERATING SPECIFICATIONS FOR MSD BLASTER IGNITION
Operating Voltage: +12 VDC Negative Ground
Current Requirements: 7.5 Amps Max
Spark Duration: 20° Crankshaft Rotation
Energy Output Max: 180 mJ Stored Energy (inductive ignition)
Weight and Size: 1.25 lbs, 6"Lx3.5"Wx1.75"H
Voltage Output Max: Primary: 420-450 Volts
Secondary: 40,000 Volts (Blaster Coil)
The only other thing I can think of is thge ECU itself is bad....is this possible?
PS: thanks TexasHonda for the info on the V.S.S
Old Oct 18, 2007 | 08:16 PM
TexasHonda's Avatar
Short the service check connector and see what code/s are present.
Check the blk/yel wire at the distributor connector for 12V w/ keyswitch On. If no voltage, a keyswitch problem is indicated. If you have voltage, check for spark to a plug grounded to the engine. You should get a bright blue/pink spark.
Does the bad performance coincide w/ installation of aftermarket coil?
Everybody always suspects the ECU, but they very rarely are the problem.
good luck
Old Oct 18, 2007 | 09:00 PM
7th Gear
well sh*&!
Finally found the problem....the V.S.S wires were shorting out on the block which caused my back-up lights, Meter lights, Clock, Security Fuse (#16) to blow.....and I even checked that damn fuse before. I suppose I was too pissed off the first time to pay close attention to what the hell I was doing
Thanks to everyone for the advice and help! This is a great forum!
tildeath
Old Nov 6, 2007 | 09:29 AM
CL Driver's Avatar
good!
Bobinator
1G RDX Photograph Gallery
17
Jan 4, 2021 01:30 PM
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
g1underground
Mid-Atlantic
Sep 23, 2015 01:18 AM
