1998 CL 2.3 Starting Problem
My CL won't start. When I turned the ignition key, I only heard a "click". Nothing turned. I thought it was a battery so I replaced it, but it's not it. I suspect that this is something simple, like a fuse blown, so I checked all the fuses in the engine compartment. I found a few fuses near the break pedal (this CL is automatic). But I don't know which is which without the repair manual. Does anyone have the same problem?
Thanks, Vic
Thanks, Vic
CL Starter Problem
Originally Posted by AznX TL
its your starter, clicking is usually 2 things.....
the battery clicks when it has a little bit of juice, and the starter clicks when its out.
That was it. For the benefit of other people who might have this problem. I discovered the Starter issue by accident. I pushed the car out of the garage preparing to tow it to the repair shop.
And this moves the (worn) starter a little, enough to start without problem. I saved $50 towing cost and drove it to the repair shop, had the starter checked out - it's worn out after 120K. Had it replaced, and it runs like a champ again.
This car has treated me well. It hums softly and runs like a champ at 120K.
Best, Vic
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
