1998 2.3 may end up in a corn field on fire (tps map issues)
Old Feb 5, 2009 | 03:22 PM
davida3392's Avatar
4th Gear
Angry 1998 2.3 may end up in a corn field on fire (tps map issues)
Car is throwing out trouble codes like crazy. my vss is bad, which is an easy fix. my map was bad. bought one from partstrain.com, it wasn't the right one, the dealership matched the online price (economy must be HORRIBLE, dealerships are haggling).
the engine speed in neutral consistently jumps between 1000 and 2000 rpm.
my two other trouble codes were the map and the tps. i bought a tps, though i don't think i tuned it right. in installed the map and it made no noticeable difference.
question is this. will a map sensor malfunction cause an engine to rev uncontrollably, or is this the poorly tuned (high voltage reading) tps? i won't have time to try and tune it on saturday, and hopefully this will resolve the issue. if not where do i go from there? thanks for the input.
-David
Old Feb 11, 2009 | 07:12 PM
TexasHonda's Avatar
Only reason I've seen for idle oscillating up/down is excess air supply from leaking PCV hose, vacuum line, Fast Idle Thermo Valve stuck open, intake manifold leak, etc.
good luck
cycdaniel
Dec 17, 2019 10:58 AM
Mr.Tea
1/2G MDX (2001-2013)
26
Oct 9, 2015 04:27 PM
govtcheez
Oct 1, 2015 12:21 AM
carz0159
Sep 20, 2015 06:11 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
