f20b swap and tuck on a 97
wire brushed block ,partiot blue valve cover ,kaizenspeed balance shaft delete and also manual tensioner conversion, ported intake, chasebays harness and braided clutch line, fidanza flywheel, spec clutch, true cold air also has a wraped header that about covers the engine this is the second f20b i have had in there. the engine is tuned on a p28 with a neptune demon the first engine made 169 whp on the dyno at the end of its life which it was pretty tired less than 100 psi on a compression test( i run her hard) Hopefully the new engine will break 185-190 post up some comment let me know what ur think of the setup i will post some exterior pics once i get it running currently dealing with chase bay problems but hopefully it will be going soon
Big plans not enough $$$
Yeah, theyre are pretty cool, a guy that works there is a member here and he has his s2000 with a j32 swap and turbo.
https://acurazine.com/forums/car-talk-5/turbo-j32-s2000-build-thread-844557/
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
09-28-2015 06:51 PM
