typical speedo issue. please help.
Old Aug 5, 2012 | 10:14 AM
nirvanacarl's Avatar
5th Gear
first off hi to everyone im new. just picked up a 1998 cl 2.3 manual. was wondering if the cluster will need programmed if i get a new one. i think we have chased the issues down. scanned it today got p1259 and p0420 codes. but the main issue is the speedo. the speedometer,trip, and odometer are not working. does the bouncing thing. it will work occasionally for a couple miles. it reads 20 when u turn the ignition on with and without the VSS connected so we figured its not that. ive taken the cluster out and unplugged it and plugged it back it and didnt really work. someone suggested it might be the brakes but we put the scanner on it and its reading the speed so the computer is sending the speed to the cluster but its not picking up. am hoping for any help that you guys can give me. including leads on buying a cluster. preferably used(well cheaper at least) also wondering if it will need programmed. thanks in advance
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
dirleton
Sep 25, 2015 12:25 AM
