It is the typical story of buying a car from a little old lady whom had put few miles on it in 18 years; 124K. This CL is damn near pristine,
I know of no accident in which it was involved but the SRS light on the dash stays on, always when running, kind of annoying.
Is there a way to turn this light off?
Any information and help is greatly appreciated, thank you.
frankjnjr
close
- Join DateJul 2014
- Locationbaltimore, md
- Age83
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:137 Times in 110 Posts
FWIW: Considerable info. on this forum, as well as Youtube, relative to re-setting the SRS light. From a peace of mind perspective, especially, if you are not comfortable experimenting with the SRS system, ( CAN BE DANGEROUS ) you may want to have the system professionally checked, to insure the system has no faults. If no system faults exist, the SRS light can be easily re-set by any shop, that has the proper scanner. I believe there is a way to retrieve SRS codes manually as well, (Forum search is your friend), Important to note, that your air bags will probably NOT deploy in a collision, if the SRS light is on!
Thank you for the information. I will check the forum(s) and good ole YouTube.
Again, thank you, especially on the deployment issue.
- 2009 TSX VSA light Airbag light on after Accident. no airbag deployed...Please Help
- Check Airbag Warning - Got Code 31-10 "Permanent DTC open in the drivers side airbag"
- 03 steering wheel/airbag on a 01? (single vs dual stage airbag)
- 07-08 TL Driverside Airbag or Airbag cover!!!!
- srs light and side airbag light?
