2.2 Intake Install
Old Jul 6, 2005 | 05:54 PM
klepto's Avatar
2.2 Intake Install
Disclaimer: by using these guides, you are removing me from any liability that is related to any injury that might occur. I would suggest having a friend help you on these installs, if you are unsure about your abilities for any of these projects, get a professional to do it.
Credit goes to wes (llwesman@yahoo.com) for the original guide and pics
AEM V2 Intake install
Estimated Time: ~1 hour
1. Here's your engine bay, if you've got a 2.2/2.3 CL. Start by lifting up your hood
2. Next, remove this little piece of plastic, it should pull right out.
3. Disconnect these two pieces next.
4. Remove this cover with a screwdriver.
5. Remove the stock filter next, it should pull right out.
6. Next, pull this piece out.
7. Then, carefully pull out the plastic plugs under the wheel well in order to access the stock air box. Be careful not to break the plugs. The wheel well should allow you to pull the air box out easily. It makes it easier if you turn the wheel away from the car as shown in the picture. If you are installing a Cold Air Intake (CAI), then leave the wheel well open, if you are installing a short ram or V2, go ahead and close it up with the plastic plugs.
8. Next, remove this piece of plastic piping.
9. Then rip out this piece.
10. To finish, plug the rubber piping into the intake. It's the only thing that attaches to the intake and there's really only one place you can put it.
11. Next, clamp the intake to the engine bay as shown at the top of this picture. A screw/washer combination is usually included and attaches to the forked spot on the intake. In this picture the connection is partially covered by wiring.
12. Viola, there you go. Reset your ECU if you like by disconnecting the battery for about 10 min, or just leave it as is and your car will adjust in a couple weeks.
If you are installing a Cold Air Intake (CAI), install the piping as indicated, then attach the filter which sits inside the wheel well. The intake feeds directly into the hole where the old filter sat atop.
Old Jul 14, 2005 | 05:02 PM
LLWesMan's Avatar
Ahhhhhhhh
My left hand is pretty.
Old Jul 14, 2005 | 07:07 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
damn sexy
Old Aug 2, 2005 | 05:25 PM
lima's Avatar
97 2.2CL?for how long??
3 questions:
1)wtf is an ECU?
2)do you notice a difference in performance?
3)wtf can I get one????
I don't really understand steps 7 & 8, but if I ever get down to doing this, I might understand it then.
thanks for the post.
Old Aug 2, 2005 | 05:29 PM
klepto's Avatar
Originally Posted by lima
3 questions:
1)wtf is an ECU?
1) electronic control unit. Basically your cars computer brain.
2) that isnt my car, but people have said that theyve noticed an increase in performance and in sound
3) theyre all over ebay
Old Aug 2, 2005 | 08:26 PM
DaInFaMMuS1's Avatar
this DIY is awesome...used it today to install my V2. the only thing is that when u remove the resonator from the bottom, there is a bolt and a snap thingy thats keeping it in, and it takes a lil maneuvering to get the resonator out w/o lifting ur car up. Also, the clamping into the engine bay didnt line up exactly, so i screwed the bolt in slightly sideways and put rubber tubing around the screw since the 1 that came with the bolt didnt let me screw it in properly so now it sits pretty good. the tubing to connect the V2 and the tube i pulled out the stock intake also didnt match up, so i fabricated 1 with some rubber tubing, wrapped it in electrical tape and claped both sides to the hoses..works like a dream =). Great investment, even used
Old Aug 2, 2005 | 09:01 PM
LLWesMan's Avatar
Ahhhhhhhh
You're welcome .
Old Aug 30, 2005 | 11:13 PM
Ezekiel25_17's Avatar
I was trying to install the V2 intake. However, I ran into couple problems. The intake is slightly different, but essentially the same. First, I don't understand how to access the intake resonator from the wheelwell. Secondly, the piece that needs to be removed at step 9 is like a small can and I'm not sure if I could remove it or not. Then, there is this 1 cm hole on the side of the intake pipe. Manual says I should plug it in with the given rubber "nipple" but sweet jesus its hard to fit in!!!! Any ideas on this guys?? Thanks.
Old Sep 1, 2005 | 11:41 AM
Slooo97CL's Avatar
what piece is this, i dont remember taking that out.
and heres a pic of the v1 cai
Old Sep 1, 2005 | 02:06 PM
LLWesMan's Avatar
Ahhhhhhhh
Your memory isn't very good, its part of the stock intake.
Old Sep 1, 2005 | 02:34 PM
Slooo97CL's Avatar
its been a while, but ya my memory is shot
Old Sep 2, 2005 | 01:11 AM
LLWesMan's Avatar
Ahhhhhhhh
Old Sep 2, 2005 | 01:12 AM
LLWesMan's Avatar
Ahhhhhhhh
Why isn't it working!?
Old Sep 10, 2005 | 01:12 PM
ninetysevencl's Avatar
step 9:
that little canister has a rubber hose connected to it that connects to a little battery type thing (says 12V on it so im assuming it powers something) . am i supposed to just rip out the canister and leave the hose or rip out the canister with the hose?
Old Sep 10, 2005 | 01:31 PM
LLWesMan's Avatar
Ahhhhhhhh
Originally Posted by ninetysevencl
step 9:
Not sure what exactly you're referring to, take a pic and circle it?
Old Sep 10, 2005 | 03:14 PM
nvm i figured it out, thanks tho
Old Feb 14, 2006 | 09:47 AM
jimmyeatmud's Avatar
I am thinking of getting a CAI (Thanks for the DIY) but I am unable to find any for the 97 2.2 cl.
I have done a fair amount of searching but have come up empty handed. Is the 97 accord F22b1 the exact same? To be totally redundant. If I purchase a 97' accord CAI, will have any modding to do, other than to plug the thing in?
Old Feb 14, 2006 | 11:18 AM
klepto's Avatar
please search. this topic has been discussed millions of times. 94-97 accord 4cyl parts will fit our car.
Old Feb 14, 2006 | 11:37 AM
I was looking for CAI intake stuff and couldn't find it. I probably could have done some searches with different key words. I appreciate the reply though, thanks.
Old Feb 15, 2006 | 10:29 AM
(Mid-Atlantic)
go to www.motors.ebay.com search for 97 accord 2.2 intake u'll get 10,000 replies
Old Feb 15, 2006 | 11:14 AM
done and done. I found the cheapo intakes I was looking for. Quick question: Most of the auctions do not have the diameter's posted. Should I just order one and measure it and then order the bypass valve or can I assume that its 2.5"?
Old Feb 15, 2006 | 02:33 PM
(Mid-Atlantic)
I would wait and measure, it depends on the intake, my bypass valve for my 3.0 was 2.75" but maybe that's cuz of the different throttle body
Old May 1, 2006 | 11:25 PM
1V4N's Avatar
1st Gen CL Noob
Just got a Short Ram Intake installed (somewhat).
However I got to the point where the intake is secured to the Throttle Body.
I have the 2.3CL, and noticed there isn't actually a rubber hose that connects to the nipple on the intake. Instead of a simple rubber hose, its a metal one!
Obviously it won't connect to the metal nipple on the intake.
Since I installed this late tonight, I did a ghetto mod whereby I generously wrapped a good secure amount of electrical tape to connect both metal connections, then used the clip over top of the taped area temporarily until I can get to an auto shop to pick up a 1cm diameter rubber hose to permanently join the 2.
Went for a drive, but as most mention there isn't much difference, except under full throttle it emits a nice sound.
My question is, do I need to remove the lower part of the stock intake (the one in the fender well) or can I simply just leave that in place?
Any answers would be greatly appreciated.
Old May 2, 2006 | 01:40 AM
shnee's Avatar
Land of Pleasant Living
might as well take it out?
in this guide, it says "if youre installing a cai, leave the wheel well open"
how can you just leave that open?
i dont get it.. when i did mine, everything was all connected, i just pryed the plastic open like in the pic.. you couldnt just leave that pryed open, so i duno what i was supposed to do..
any help?
Old May 2, 2006 | 03:27 PM
LLWesMan's Avatar
Ahhhhhhhh
any help?
The only reason that you're supposed to leave the wheel well open is so that you can put the filter for the CAI into it, you close it back when you're done.
Old May 4, 2006 | 10:50 PM
Racer510dude's Avatar
Did you have to do any drilling in order to fit the full piping into the hole towards the resonator area? I remember installing a CAI into my old 93 accord and drilling the hole was a pain in the ass.
Old May 5, 2006 | 06:48 PM
AznX TL's Avatar
where is....
what filter is this? i was looking at it and it said something like fuel filter i think
and is taking out the stock airbox necessary for short ram? or can i just leave it there?
Old May 5, 2006 | 10:21 PM
AznX TL's Avatar
where is....
nvm i took that out, and i took out the stock airbox.....
what about the wires that attached to this...........
Old May 6, 2006 | 05:16 PM
kraftey's Avatar
I was a little confused at that exact same point. They don't really give you anything to connect the metal one to the intake. They say you're supposed to remove that whole setup (with the metal hose) but I wasn't up to that, so I just left it in there. But I just took the 3 pieces of hose they give you to replace the whole system, found the one that would fit there and cut off a little piece, then used two clamps to hold it on.
Old May 14, 2006 | 06:35 PM
ItsDave's Avatar
remove the two metal hoses, they should be connected together in the middle. Replace them with the rubber hoses that should come with the intake.
Old May 23, 2006 | 05:15 PM
STL+3.0CL's Avatar
Matt
You should really have a bypass valve on that v1 CAI! Hope you dont drive in a puddle and flood your engine.
Old Jun 15, 2006 | 06:02 PM
AznX TL's Avatar
where is....
once again i want to know what wires were attached to this because my mechanic is saying it was a airflow sensor and now the throttle body doesnt know when to open up
Old Jun 15, 2006 | 08:40 PM
herbalist's Avatar
chips and smokes, lets go
your problem must be from something else. i removed that piece as i'm sure everyone else has to who installed an intake. i only remember there being one small hose attached to that piece. i unplugged it and thats it. but as for what is causing you problem maybe someone else could help you..
Old Nov 24, 2006 | 08:58 AM
twizy's Avatar
When you take out the 2 plastic plugs under the wheel well, do you just pop the inner circle out or do you take the entire plug out? I tried just popping the inner circle out but i ended up cracking it and now I'm afraid of destroying the entire plug if I keep trying. Please advise, thanks.
Old Nov 28, 2006 | 01:15 PM
hornedfrog2000's Avatar
B A N N E D
Yeah, how do you get them out? The plugs that is
Old Nov 29, 2006 | 10:52 PM
5-speed's Avatar
4x4- fat chicks cant jump
pop the inner circle out, then you should be able to pull the whole clip out. its really easy to break them, so be careful. I had to super glue a few back together cause I was too lazy to go to the stealership and buy new ones
Old Feb 23, 2007 | 09:20 PM
Nhatv6's Avatar
does anybody know if it would pass the inspection? I just heard that with the cold air intake that it won't pass the inspection
Old Feb 23, 2007 | 09:47 PM
B A N N E D
I heard something about that too, and also heard that some of them maybe illegal...?
Old Feb 24, 2007 | 04:02 AM
klepto's Avatar
i dont know, but AEM claims to be 50 state carb legal. it comes with the carb sticker
Old Feb 24, 2007 | 06:53 AM
Nhatv6's Avatar
I better check it with the people that work at the inspection hopefully they say it will pass the next time.
