zex help
Old 06-13-2002 | 02:43 AM
Yajarobi420's Avatar
zex help
where do i connect the hoses for the intake manifold and the fuel regulator. and which one is the tps?
Old 06-13-2002 | 12:05 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
I tried to get some pics. but now there's a thunderstorm, so I could only get 2 pics.
The 1st pic shows where the hoses connect to the back of the intake manifold. Look for the "U" shaped hose that's on the back of the intake maifold. You will remove this. Look where the left end of the "U" hose was connected, this is where you'll attach the hose that goes the "Intake" connector on the Zex management Unit.
Look where the right end of the "U" hose was connected, this is where you'll attach the hose that goes to the "Regulator" connector on the Zex management Unit.
Check out my next pic for location on the Zex Management Unit.
23's Avatar
23
I think the tps is red and black if I can remember from the vemom install.
Old 06-13-2002 | 12:07 PM
This pic shows where the 2 hoses are located on the Management Unit. The one on the left is the "Intake" and the one on the right is the "Regulator".
These should be indicated on the Unit (I'm doing this from memory).
Old 06-13-2002 | 12:27 PM
Correct!
The TPS is located on oposite end of the throttle linkage shaft on the throttle body. The TPS has a 3-wire electrical connection. It can be identified by the colors of the wires: green/black; red/black; and yellow/blue.
Good Luck, and have fun!
Old 06-13-2002 | 12:29 PM
all i need to do now is connect the white wire to the tps and i dunno where that is. theres a couple different plug things on the throttle body. and does the red wire need to be attatched to the battery and the switch?
Old 06-13-2002 | 12:42 PM
Make sure you ground the Management Unit with the black wire, then take the red wire with the fuse link (connected to the arming switch) and tap it to a 12-volt power source under the dash. Take the other lead from the arming switch and connect it to the red wire on the Management Unit.
As for the TPS: look for the plug that has these wire combinations (green/black; red/black; and yellow/blue). It will be the ONLY plug with these exact wire combinations. Connect the white wire from the Management Unit to the red/black wire.
Old 06-13-2002 | 01:36 PM
woohoo. im finished. thanks for all the help.
Old 06-13-2002 | 02:34 PM
You're welcome!
Have fun!
S1CK TypeS
12-29-2007 12:40 AM
PiZauL
10-19-2007 12:52 PM
jermz123
03-11-2005 12:03 AM
AcurajL
03-12-2003 04:14 PM
CLSmike
06-10-2002 03:28 AM
