WW Front Lip Question
I just ordered my WW lip yesterday and i was wondering if anyone painted theirs themselves. How hard can it be - just sand lightly, prime, paint, and clear coat. I have a garage for drying, so is this a really bad idea - i haven't done anything like this before but worse case if it turns out bad, I'll just get it done by a body shop anyway so i should give it a try, right?
also does 3m tape hold it or screws? does the original bumper piece come off? and i guess i'll need someone to help me put it on?
thnks (-:
thnks (-:
i dont know if you should try and paint it yourself but the 3m tape holds it on very well but just incase i put 2 screws on each side of the wheel well. you dont need to take anything off the car! please dont do that all you do is just put the lip right on. and youll only need 1 other person to help you i did it myself so it should be hard at all. If you go to wingswest.com they have instructions on how to put it on.but just do what i said instead.
AWD Torque Monster
u could paint it if u want. its such a small piece. i painted all my oem lower moldings and they held up fine for last 2 years. it will take a beating on the front so a professional jpb with flex agents would be better.
What can I get ya?
If you dont have a sprayer I wouldnt try it. Unless you want it to look like shit, take it somewhere. You will be happy that you did in the end.
I would use the screws they sent you and the tape to install it. But first you must get it painted. I had mine done at a body shop and it came out flawless. If it's not a show car and you don't care about the good from far but far from good look try painting it in your garage
DOOKS of hazard!!!!
bro. go to a local paint mixing store (not lowes etc), take your paint code number in (on side of door) ask them for two cans of spray paint in this and explain its going on a piece of polyurathane abs plastic....ask them if they can add a fixitive to make it flexable.....they can if theyre pro....and buy cllear coat and primer in spray can at the same time.......YOU CAN DO IT MAN!!!!!!!!!!!!!!
Yeah i did it myself!! All i did was buy primer and then i bought the paint from acura and sprayed it like 3 layers and then i put clear coat. it looks good too
thanks! i'll let you know how it turns out (-:
acura-cl.com OG
112K and on 1st tranny!
some around here in charlotte NC include "sherman williams" "dupont" and " ace truevalue"
here's a thought, maybe go to a body shop and have them mix you a good batch and it will be perfect paint mix and you will have a batch for backup in the future? couldn't cost more than 35-40 bucks.
Pegon95
08-31-2015 02:18 PM
