windshield washer
Old Apr 20, 2004 | 06:00 PM
bmterp's Avatar
windshield washer
ok, so now that i have my car back from the shop, i noticed that my windshield washer doesn't work. i filled it the rest of the way, and there's plenty of fluid. when i pull on the control arm and it makes a whining sound, but can't get more than a dribble to come out. i also checked to see that the nozzles aren't clogged and the short piece of tubing that i could see coming from the top of the hood looks fine.
before i call the body shop up to tell them there's something new wrong with my car, any more suggestions for places to look for problems?
Old Apr 20, 2004 | 06:43 PM
Repo1234's Avatar
My car is the same way. For some reason it has no pressure whatsoever. I looked under the hood and it looks like the hood was smashing the little tube agaisnt a bolt. You might want to look to see if you have the same problem. Even though I moved the tube it still has the same problem. I dont really care though because i hardly use it anyway.
Old Apr 20, 2004 | 07:32 PM
bmterp's Avatar
tried it, didn't fix anything...annoying as hell though, 'cause i wash my windshield about 5 times a day.
Old Apr 21, 2004 | 01:30 AM
RippinRide's Avatar
The windshield washer pumps tend to go out every so often. You could try changing it, if all else fails. Its not too hard to do it yourself. Though i've never done one on the CL.
Old Apr 21, 2004 | 03:38 PM
rad_cl_racer's Avatar
Fawkin Gruvin
how do i aim the little sprayers? i have good presure and a good stream of wash comming from the jets, but only 2 of the 4 jets are hitting the windshield. can i ajust the jets? / aim them ?
Old Apr 21, 2004 | 04:12 PM
h22turboCL's Avatar
A-CL's Most Wanted
yes, you can. what you do is, have a friend help you. either one of you, go inside the car and toggle with the wiper/washers, while the other person toggles with the sprayers. find a pin, or a needle and stick it into the nozzle. you can adjust it that way. keep adjusting till it is shooting in the right place.
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
Cexarin
Sep 23, 2015 07:43 PM
