Window regulator replacement
I hate these windows with a passion. Where is the best place to find the part to replace it. Not going to acura or a mechanic to get raped. im going to do the install myself. Any input is greatly appreciated.
eBay... get window regulator for 97 accord 2 door... fits our cars, costs about 50 bucks. your one-touch down will no longer work, but its much better than spending 4x that amount for acura part
DIY is here:
http://home.comcast.net/~bobobutler/...ra_Window.html
DIY is here:
hey, go to 1AAUTO.com, they have the ones that work (one touch on mine works), and i think they are only charging like 67.00 right now, which is damn cheap for one of those, 2 months ago they were the cheapest at 93.00...check them out, i was damn satisfied with em
Good luck
Duck
oh, and btw, the only way to manually push it up is to keep your door panel off til you change the regulator
Good luck
Duck
Originally Posted by Slooo97CL
thanks guy i found one on ebay...now i have to wait for this bs...
how can i get my window to go up temporarily? Can i manually push it up...its stuck all the way down.
when mine went, it just WENT... no going slowly, just went down and never came back up... and at the worst time... right after getting on the NJ turnpike goign to Atlantic City
the problem with mine was the cable got kinked or was messed up... i thin kthe actual motor was OK
Originally Posted by bebop.fey
Did all of your windows move up slowly?? cause mine are fuckin SLOW and it is pissing me off ! is my window regulator going out?
Originally Posted by Smalls
I already bought a replacement for 70 bucks including shipping off ebay.
I got to get this window wedged up now, cant leave my car anywhere unattended.
how would that cause it?
many people on here have done this. It saves the regulator, not kill it. Your regulator had lots of wear and tear before you applied this. You just did it too late.
another one bites the dust --
i'm new, but i've been lurking for a few weeks, today my girlfriend was giving a co-worker a ride home and he slammed the door pretty hard when he left (the window was down) it wouldn't roll up when my girl got on the freeway.
i got the door panel off (thanks to some nice tips and diys) and it seems like it is a regulator problem - the cables are all jacked. i took the handle off my plunger and cut a notch in the top of it and shoved it in there to hold it up. i just ordered a regulator that says it's for a 94-97 2dr accord rh side, (ebay $47.95 shipped.) i just wanna confirm that shit'll work and see if anyone has any tips for me before i start.
thanks -
brad
green 2.2 '97 by the way 84k
thanks -
brad
thanks -
brad
thanks -
brad
but since you live so close, i might be able to hook u up.
test out the window for a day or so before putting the door panel back on for minor adjustments, and wear gloves when you put the door panel back on or else risk cutting your finger off. Also buy that silicone spray and lube it up.
thanks again.
b
Originally Posted by h2o-pr00f
when you replace the regulator how much faster do the windows roll up?
piece of shit. . . i installed the regulator no problem, and i've spent a night and a morning trying to get the top lip of the door panel over the top edge of the metal part of the door. . .
do i just suck at this? any tips?
man, i remember i was fucking with that forever..
i cant remember what the problem was, but i remember being like "holy shit, im such an idiot.. i cant believe i spent all that time on this shit because of that"
maybe stop thinking about it and just go to put it on with a fresh state of mind..
i wish i remembered what it was, because it was something really stupid and simple
Originally Posted by PLuGiNn
anyway to add onetouch to both doors ? also looking for one touch up
Originally Posted by Gaujo
i believe i read before that on another car WD40 could break down the rubber insulation
Good luck
Duck
Put the window down when putting the door panel back on.
Also, loosen the screws around the door handle (latch) that hold it in place. let it have some "give"
you will have it on in seconds.
Well my passanger window also went out this weekend. I have a 1997 3.0 V6 CL and found this part online but not sure if it will work for the 3.0. Any suggestions??
http://www.1aauto.com/1A/WindowRegul...1331435/407010
The other ones I found are $100 or more. I also found one on ebay but a used one with all these problems does not sound too good.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Any suggestions and level of difficulty for a begginner would be great. I was quoted for parts/labor $300 from dealer near work and will spend that if I cant do it myself which I think I can as I got the door panel off to lift the window back up and wedge it up with a stick. Any help would be awesome...
Thanks,
Eb
Thanks,
Eb
$300 that's what I paid, since then i've had the door panel on and off a dozen times and wish I'da done it myself. The 1st link you posted will work, or try ebay, they have lots of regulators on there for cheap. Also, there's diy guides on here of step by step directions, you should be able to do it yourself if you are mechanically inclined.
Thanks for the info. I got the DIY guide and me and a buddy are going to try it out as soon as I get the parts. I went to 3 stores here and all had it for around $105 on special order. So I may just buy it online from here
and hope to get it soon as I dont want my car to get broken into. Is everyone sure this (4 cylinder) listed part will work with my 3.0 v6? If so I will buy it tonight and hope to get it by the weekend. Or let me know if you think this one below would be better since it is off an acura but is USED!!!
Once I hear a few opinions I will buy it and try it on out.
By the way you guys rock as I love this site and it has helped me fix a bunch of parts on my car so far. Great information and everyone is real cool.
Thanks gang,
Eb
Thanks gang,
Eb
