Window Problem
Old Jan 30, 2007 | 03:07 PM
herbalist's Avatar
chips and smokes, lets go
Window Problem
so my passenger side window has been slow for a while. i replaced the regulator and its still slow. i figued out that the problem i'm having is with the plastic/rubber piece that makes contact with the window. i'm not talking about the track at the side of the door, its the piece at the bottom where the glass comes out of the door. either way, this plastic/rubber piece is pushing really hard on the window which makes it hard for it to go up or down. too much friction yo. any ideas?
Old Jan 30, 2007 | 03:11 PM
ajtcl's Avatar
Peace, Love & Acura
Powdered graphite might help, or shave the rubber... Not sure how you would do that. But, try the powdered graphite first.
Old Jan 30, 2007 | 03:16 PM
teh CL's Avatar
powdered graphite?
Old Jan 30, 2007 | 03:18 PM
ajtcl's Avatar
Peace, Love & Acura
It is a dry lubricant used for locks and small mechanisms. You could also try glyserin, but it is wet and would likely smear.
Old Jan 30, 2007 | 03:20 PM
teh CL's Avatar
i c..
Old Jan 30, 2007 | 03:23 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Put silicone lube in both the tracks
Old Jan 30, 2007 | 03:39 PM
herbalist's Avatar
i've tried putting lube in the tracks but its not cutting it. putting the lube where it really needs it will make it smear all over my window.
ajtcl, where can i get this powdered graphite.
Old Jan 30, 2007 | 03:44 PM
AznX TL's Avatar
where is....
take it off first to see if its really the problem
Old Jan 30, 2007 | 03:59 PM
herbalist's Avatar
i'm positive i've identified the right cause of the problem. before i switched the regulator my window was obvisously slow. after i switched it, its still as slow as before. i also compared both regulators when the door was apart and they seemed to preform the same. for some reason the window is just pressing too hard against the trim piece at the bottom. a lube for it would be a good idea though. if the window is a little bit wet it performs 10 times better.
Old Jan 30, 2007 | 09:05 PM
SupraManAG's Avatar
One custom CL
silicone grease in spray form
best stuff. dont use white lithium because it thickens and symptoms get worst
Old Jan 30, 2007 | 10:36 PM
ZeroCL's Avatar
W WHIP.
Please post what works and what doesnt when you find out, my passenger side window is slow too. Thanks!
Old Jan 30, 2007 | 10:40 PM
(Mid-Atlantic)
Silicone grease works wonders as I said above
Old Jan 31, 2007 | 07:36 AM
BlakeandMrsCL's Avatar
Yeah, my driver door had the same prob, i changed the regulator, but it was still slow, i took it all of, and just saw that when i put it back on, i didnt line up a couple of things, amke sure the bar inside the door that holds the regulator is lined up correct, juss see if everythign is all in its place. Too much fricition might burn out yoru regulator again
ya ya yaya ya
Old Jan 31, 2007 | 08:43 AM
keithseymour's Avatar
could you maybe stick a loose razor blade where it's rubbing and shave some of the rubber off? Just a thought.
Old Jan 31, 2007 | 08:45 AM
AznX TL's Avatar
where is....
ya ya yaya ya
im just sayin this because i didnt have a rubber thing on my drivers side door since i bought the car until acouple weeks ago, and its always been balls slow. but it doesnt look like the rubber thing actually rubs really hard or sticks to it.
Old Jan 31, 2007 | 08:46 AM
(Mid-Atlantic)
im just sayin this because i didnt have a rubber thing on my drivers side door since i bought the car until acouple weeks ago when blackack hooked it up, and its always been balls slow. but it doesnt look like the rubber thing actually rubs really hard or sticks to it.
Fixed
Old Jan 31, 2007 | 08:50 AM
AznX TL's Avatar
where is....
Fixed
yes, thanks to black i got one and i almost broke it when putting it on
Old Jan 31, 2007 | 09:23 AM
(Mid-Atlantic)
Old Jan 31, 2007 | 11:26 AM
herbalist's Avatar
i'm pretty sure i put it back together the right way but you never know. i guess i have to take it apart again and find the cause of the problem.
Old Jan 31, 2007 | 06:13 PM
SupraManAG's Avatar
One custom CL
just spray the damn thing
Old Jan 31, 2007 | 11:34 PM
(Mid-Atlantic)
finally a voice of reason that agrees with me
Old Feb 3, 2007 | 06:13 AM
woodek's Avatar
Is it slow all the way (from the down position to the top) or does it get worse as it goes up?
If it's slow, its gona' strain the motor. Been there done that. I pulled the rubber that the window rides against when up. It kinda looks like shit when the window's down, but there is no strain on the motor, and I live in Fla, so my windows are normally up anyway. You can access it once the window is down and it pops right out. It's at the back and runs flat against the window when it's up. There are two screw cover behind there. The rubber piece inside the door (in the track) shouldn't hinder window movement at all unless it's bent.
I removed my window rubber and there is no wind sound or leaking. In fact, Acura replaced my motor twice (imagine that), and both times, they left that piece out. I bitched both times, but after a while I realized that this was what was strining MY motor, and just left it out. She's smooth now and havent repleced a motor since. (I work on an air force base and have to roll my window up and down constantly for badging).
Old Feb 3, 2007 | 04:30 PM
AgentOrange's Avatar
mines still slow too after i installed my regulator. I know its rubbing on the upper window plastic housing. Im not sure how to "bend" this out of the way. there isnt any clearance
Old Feb 3, 2007 | 05:15 PM
spiderman3098's Avatar
if he sprays wont it smear all over his window which doesnt just look like dogmeat it also be dangerous cause it reduces ur visibilty
Old Feb 3, 2007 | 05:42 PM
herbalist's Avatar
exactly. spraying the lube where i need it will make it smear all over the window. i've sprayed the tracks already but it could still be better.
Old Feb 3, 2007 | 05:55 PM
Mach30SiR's Avatar
Bagel Bomber
have you tried the graphite polwder yet? I have the same problem, but it hasn't bothered me enough to find the cause. I think graphite powder is your best bet, and while your at it put some on your key and put your key in all the locks to lube them up.
Old Feb 3, 2007 | 11:49 PM
SupraManAG's Avatar
One custom CL
spray spray spray
and for all u "oh my bitchyness i got jizz all over my window". just clean it. it wont keep rubbing off. Spray the 2 far ends of the wondow. Make sure you spray the exposed rail as well. Dont be hasty.
SidhuSaaB
May 30, 2020 12:40 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
wcimo
Sep 21, 2015 10:55 AM
ahsm
Sep 9, 2015 08:35 AM
