Window Doesnt Work!!!
Yo guys,
Recently my driver side window gave out. When i pulled off the panel i checked it out and it was a mess. All i found was that the cable was snapped. I opened up the window motor and pulled the cable out. What do i need to do? Do i just need a cable? I know its a common problem but im not sure where to start. Where do i get the cable? please give me a hand guys thanks.
...is now Carbon Fiber'd
nope its all one piece...so you have to buy the whole thing! same thing happen too me. And it should be the same though out the models, just make sure you tell them what side, because it curves.
same thing happened to me, it sucks, but its pretty straightforward to change, just make sure you have someone give you a hand, and it should be good to go......and as hybridnrg said, its a motor/regulator, one piece, make sure you get one designed for the cl ( a 94-97 accord will work, but most times the one touch down feature wont work). and yes, they are all the same, regardless of 2.2, 2.3, or 3.0.........
good luck
good luck
TLDude876
12-28-2016 03:18 PM
ahsm
09-09-2015 08:35 AM
