Widebody Cl!!!!
Old Jan 15, 2004 | 12:46 PM
rmh3093's Avatar
Pass the dutchie!
Widebody Cl!!!!
I see that a bunch of people are taking body kits from the 98 Accord and getting them molded to their Cl. I wanna mold a widebody kit to my car which I assume is possible but my question is on all of the kits I see for 98 Accords, all of the front bumbers dont have a turn signal like out Cl. Some of the kits have spots for map/fog lights. Do most people tie their turn signals to their parking lights if not what do they do for turn signals?
Old Jan 15, 2004 | 12:53 PM
Cocoa's Avatar
2600lb CL
no clue but good luck on your project. seems like it'd be tight
Old Jan 15, 2004 | 01:03 PM
ib_jimmy's Avatar
I dont think anybody on here have done it....but that would be the way to do it.
Old Jan 15, 2004 | 01:07 PM
rmh3093's Avatar
Pass the dutchie!
do you think the parking light would be a legal substitute for the turn signal.... it is on the corner of the car.
Old Jan 15, 2004 | 01:22 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
that green wide body has been shown on here but no one has claimed it
try it out, i dont know, the wide body would throw off the curves of the CL
Old Jan 15, 2004 | 01:47 PM
rmh3093's Avatar
Pass the dutchie!
im not looking for an outrageous body kit here, im looking for a smooth kit, and one that has a little wider fender so i could stick some bad ass 18x10 wheels in the back, that would be so bad ass
Old Jan 15, 2004 | 01:52 PM
joeshmoe's Avatar
My Home Planet
18x10's are gonna cause more problems with your suspension than weither or not a widebody kit will make them look like they belong.
Old Jan 15, 2004 | 01:53 PM
rmh3093's Avatar
Pass the dutchie!
Something like this...
ED Type Drifter Complete Kit
here is a closer look of the lip on a different car
Old Jan 15, 2004 | 01:55 PM
rmh3093's Avatar
Pass the dutchie!
What problems will occur by wider wheels, i though suspension problems were caused by lowering the car?
Old Jan 15, 2004 | 02:08 PM
suXor's Avatar
Still trolling
Wider wheels would rub the control arm when turning (not enough offset), or rub the fender liner (too much offset)
Old Jan 15, 2004 | 02:17 PM
rmh3093's Avatar
Pass the dutchie!
but the widebody kit would fix the second problem with too much offset wouldnt it?
Old Jan 15, 2004 | 02:19 PM
CLpower's Avatar
teh Senior Instigator
yes
Old Jan 15, 2004 | 02:21 PM
rmh3093's Avatar
Pass the dutchie!
Old Jan 15, 2004 | 02:34 PM
ib_jimmy's Avatar
I dont see why its not legal...the honda civics are that way.
Old Jan 15, 2004 | 02:36 PM
DaInFaMMuS1's Avatar
yeah not to mention on the kit it seems like theres a turning signal on the kit on the second pic thas up close
Old Jan 15, 2004 | 02:48 PM
suXor's Avatar
Still trolling
No. The width would cause the outside edge of the tire to hit the fenderwhen turning. Unless you increase the diameter of the fender opening.
Old Jan 15, 2004 | 03:01 PM
CLpower's Avatar
how do you figure. If you get the right offset you won't be adding any size to the inner part of the wheel, only the outer which would lead to larger lips in the wheel. If you have fender flares you essentially are just making room for this to happen?
Old Jan 15, 2004 | 03:19 PM
rmh3093's Avatar
Pass the dutchie!
On our car the diameter of tire is 25" always usless you modify your spedometer for larger wheels. That means if someone were to put 10" wheels on their car. The maximum diameter wheel well needed is 27" for the tire to move freely with out rubbing and with out a change in offset, increase the offset (i think i have this right) and the tire moves away from the car decreasing the diameter needed in the wheel well.
I dont have a tape measure or I would go outsite in the 4 degree weather and find out how wide the wheel well is...
Old Jan 15, 2004 | 04:53 PM
suXor's Avatar
Still trolling
Damn you guys for making me do this in PS...
Normal:
Normal turned:
Flared, with wider wheels/tires:
Flared, with wider wheels/tires, turned:
As you can see, the opening in the wheel well would not be big enough, reagrdless of the flares. The tire would hit it in the front and back (turning right or left).
Solution here is stick with 8" wide wheels, and go for a bigger offset/spaccers to even up with the flares.
Old Jan 15, 2004 | 06:13 PM
rmh3093's Avatar
Pass the dutchie!
chrisbpickering: what did u use for your dimentions because u have exactly what i have cept for u dont have numbers your 10" wheel look like 11.5 compared to the 8". i didnt know the size of the wheel either but here are the differences in pivot radius between the 8" and 10" tires
8^2+12.5^2 = 13.12 13.12*2 = 26.24
10^2+12.5^2 = 13.46 13.46*2 = 26.92
26.92-26.24 = .68 ~< 3/4"
3/4" is a bit of a difference and I could see where rubbing could occur. looks like each side would only rub 3/8" and im sure that could be compensated for
Old Jan 15, 2004 | 06:15 PM
suXor's Avatar
Still trolling
I did not use numbers, just rouged it and scaled the tire larger for the 2ng group.
Your right, it could be close, and the plastic fender liner can be cut, removed, modified if need be.
Old Jan 15, 2004 | 09:21 PM
nippon_wa's Avatar
nippon_wa 2.0
[QUOTE]Originally posted by chrisbpickering
[B]Damn you guys for making me do this in PS...
hey.. then..what kinds of spacers do u think we have to use for ours? cuz.. i have flares and didn't put them yet.. it costs me alot $$$.. but.. i'll do it soon.. so.. just wanna get spacers..but dont' know where to get and which one i should get..
Thanks!
Old Jan 15, 2004 | 09:35 PM
rmh3093's Avatar
Pass the dutchie!
where did u get your flares nippon_wa and what do you mean spacers?
Old Jan 15, 2004 | 09:43 PM
nippon_wa's Avatar
nippon_wa 2.0
oh.. the flares that i got are for accords.. I dont' think they would fit perfectly unless i do the custom job..
also, i asked the shop and they said i need around $200 each side/ w/o painting.. so.. it might be over $1000... (ripped off??)
and the spacer.. i don't know the exact name of the stuff..
u know.. the things we can put in the wheels.. for the cars which have widebodykits..
ah.........................dunno:o
Old Jan 15, 2004 | 09:47 PM
rmh3093's Avatar
Pass the dutchie!
yeah all the widebody kits i've seen have been accords, looks like its going to be expensive but will look damn good after
Sep 17, 2015 09:01 PM
TSX69
1G NSX (1990-2005)
32
Jan 21, 2012 03:02 AM
Oct 11, 2011 10:17 AM
Nov 29, 2005 07:19 AM
bdimc2001
Apr 11, 2001 12:17 PM
