where is our o2 sensor?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Jtbecool
Mine was by the cat but not in it. The other one is in the header.
no, if you get a test pipe your going to have to weld in the 02 bungs. Theres one before the cat and one after the cat. The one closests to the rear of the car ( after cat ) is attached to the cat. the other is attached to the to the mid section after the header which is either attached on the rear portion of the header if aftermarket or that mid pipe...which means you'll have to either weld both bungs if your stock or just one if your not.
