Where have you seen this connector??
So im working on a custom fog project I have tried everywhere to find an oem harness to work with but have had no luck. So now im going to go with a universal fog harness but wanted to connect it securely with a factory connector at the firewall.
I need to find a connector that is like the white one in the pic. I feel like I have seen it before somewhere on the cl so im thinking if it is, then I can pick one up at the junkyard and solder it in. Any help would be appreciated, I know there are a lot of you out there with more experience ripping their cls apart and putting them back together
ps. thats not my image, borrowed it from on old post on this site
B A N N E D
turn signal light sockets is where those brown connectors normally are
as far as connecting, some universal spades should do the trick, with a little of rtv sealant over them to help keep the water out of the contacts (and making sure to stuff the contacts full die-electric grease before hand)
so im stumped again. I have everything in the pic except the white 2-pin connector. There is a brown male connector with 3 wires going into it and 2 open slots on the other side. I'm trying to figure out if theres any way I can jump this harness with a power and ground connection in place of the two pin connector
I need a way to jump this connector to connect it with my universal harness. What type of connector should i use? would a spade connector work? The one slot is going to be a (+) to the harness. the other slot is going to be a (-) grounded to the chasis.
Teaser pic, this is why I'm going thru all of this trouble.....
cycdaniel
12-17-2019 10:58 AM
polish_pat
09-25-2015 12:24 PM
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
