what's wrong w/ my techometer?
Old Nov 1, 2004 | 01:04 AM
nippon_wa's Avatar
nippon_wa 2.0
I just replaced my gagues that i bought from ebay.. it was for manual(mine is auto), so I took everything out inside and swap them..
everything works perfect and goes up smoothly except for the techometer.. the needle doesn't go up smoothly when i press gas.. but it moves..
what do you guys think the problem is??
Old Nov 1, 2004 | 01:09 AM
Hobo's Avatar
Flap.
loose connection
Old Nov 1, 2004 | 01:13 AM
nippon_wa's Avatar
nippon_wa 2.0
and.. because of that, i think my "oil pressure gauge" doesn't work either..
any specific?? details about what i have to change or look at it?
Old Nov 1, 2004 | 01:44 PM
ajbent86's Avatar
oil pressure? is that aftermarket? or do you mean the engine temp?
Old Nov 1, 2004 | 01:48 PM
wilp99's Avatar
if the guage face is bowed AT ALL it will grab the needle and make it stick. if im right then ur rpm guage stops then shoots up little by little. and gets stuck maybee on the way down in the same spot. the only thing u can do is eather re-allign the faces or super glue in one spot near the center of the guage where the needle goes thru.
Old Nov 1, 2004 | 06:29 PM
nippon_wa's Avatar
nippon_wa 2.0
ajbent86: i was talking 'bout my after market oil pressure and the stock techometer..
wilp99: I don't think it's the allign problem.. cuz when i had my old one, it had same problem.. so i thought i touched something when i changed the gauge faces.. so i changed to new one.. but still have same problem.. also, it moves as well.. but when it goes up, it stops like 0.5 sec and goes up and stops, up, stops, up.. like that.. not smooth...
hmm.. i think i should bring it to some shop..
Old Nov 1, 2004 | 09:41 PM
shineynitelite's Avatar
NAWWWWSSSSSS
get a 5 inch tach slap that baby on your dash haha.... dont you have an automatic and if so does it really matter if you have a tach then?
Old Nov 1, 2004 | 11:23 PM
nippon_wa's Avatar
nippon_wa 2.0
ur answer = no help AT ALL
Old Nov 2, 2004 | 03:53 AM
DanMan1464's Avatar
Autobot
umm
check your ground screws or something? i dunno....why did u get new gauges
your S7 looked fine to me...
Old Nov 2, 2004 | 04:26 AM
wilp99's Avatar
im tellin ya its the faces touching the needle. holding it back. take them off all to gather and see. it will work smoothly then.
Old Nov 2, 2004 | 04:28 AM
nippon_wa's Avatar
nippon_wa 2.0
Originally Posted by DanMan1464
umm
i meant.. i didn't change the gauge faces.. i changed the instrument cluster..
u know.. when u saw one of my pix, u said that "speedometer needles was pointing at 40mph"
and.. i broke the needles when i changed the gauge faces to s7..
Old Nov 2, 2004 | 04:29 AM
nippon_wa's Avatar
nippon_wa 2.0
oh..okay.. i'll try and see what's going on.. THanks
Old Nov 2, 2004 | 08:05 AM
NAWWWWSSSSSS
sorry for the unhelpful reply i thought mine were screwed in tightly on my snowmobile but they werent they were doing the same thing as your tach is doing now
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
