What's Wrong?
Old Jan 30, 2006 | 04:45 PM
blueCL's Avatar
Need For 6 Speed
Question What's Wrong?
okay so i started my car to go to the bank....i turn it on and it start's and revs up to like .5K and then the rpm just drop all the way and the car shut's off and all the lights come on
This happened like maybe 6-8 times b4 the car started up after me reving till 5K rpm right after i started the car...and i reved almost everyother time too but nothing happened until finally it started and it was fine....I went to the bank and got back in and started the car and it was fine no shuttering.
WHAT'S WRONG????
BTW i have a 99 3.0...Thank in advance guys.
Old Jan 30, 2006 | 05:42 PM
shineynitelite's Avatar
NAWWWWSSSSSS
air, fuel, spark
start w/ that
Old Jan 30, 2006 | 07:57 PM
blueCL's Avatar
Need For 6 Speed
what do i do with that lol
Old Jan 30, 2006 | 08:07 PM
wakeboardfusion's Avatar
Miss th 3.0
do you have gas?
Old Jan 30, 2006 | 08:08 PM
dragon084's Avatar
1999 CL3.0
tuneup is what he was saying.
i'd be worried about the battery/alternator....
my alternator died and i kept shutting down... sucked
Old Jan 30, 2006 | 11:51 PM
blueCL's Avatar
Need For 6 Speed
i just filled up my gas it's a full tank...my spark plugs i changed like a year ago i think with bosche platinum +4's....and with the alternator going bad do all the lights still work perfectly and the engine just goes dead??
I'm pretty sure it's not the battery
Old Jan 30, 2006 | 11:58 PM
Lunchbox's Avatar
Scissor Me Timbers!!
If his RPM is jumping up to 5k then it could be a problem with the timing or maybe even the throttle. It could be a faulty ECU as well. Sending the wrong information to the automatic choke.
Old Jan 31, 2006 | 12:17 AM
teh CL's Avatar
should do it more than once year
Old Jan 31, 2006 | 12:21 AM
NAWWWWSSSSSS
the chances of that are 1 in a hundred billion
NAWWWWSSSSSS
werd and dont get shitty bosch plugs especially not +4s
your basic ngk v-power are best
Old Jan 31, 2006 | 12:53 AM
Mulk's Avatar
The new ride
if your battery light comes on when the car is running, you could have an alternator problem. if the light isn't on but you want to be 100% positive its working fine, while the car is running, disconnect the positive battery cable, if the car stalls, the alternator is dead, if the car keeps running, the alternator is working fine.
Originally Posted by shineynitelite
air, fuel, spark
start w/ that
in other words...
check all your spark plugs, make sure none of them are loose, and make sure they are gapped properly. also check the wires, make sure the insulation isn't dry/cracked around the copper wire itself, and make sure the connections on both ends of each wire are in their correct places and tight.
check your air filter, make sure theres nothing in any part of the intake system that can restrict any kind of airflow.
check to make sure your fuel pump is working correctly, also replace your fuel filter and inspect all fuel lines for leaks or anything restricting fuel flow between the gas tank and engine. it might be a good idea to use a fuel system cleaner of some sort.
I would also recommend:
check alternator/power steering belts, just make sure they're tight and none of the pulleys are loose, check your oil leve, and check your throttle cable to make sure it isnt stuck or loose. If you get your car running normal, or close to normal, use seafoam, that should help. also clean out the throttle body with carb cleaner.
Old Jan 31, 2006 | 01:36 AM
blueCL's Avatar
Need For 6 Speed
thanks guy i'll check all of that stuff out tomorrow and i'll probably go buy new plugs. where can i get the ngk's??
Old Jan 31, 2006 | 09:20 PM
Mulk's Avatar
The new ride
I got mine on ebay for roughly $50
Old Jan 31, 2006 | 09:35 PM
NAWWWWSSSSSS
you dont NEED to spend that much money, just get some basic 2 dollar each v-powers
Old Jan 31, 2006 | 09:54 PM
ajtcl's Avatar
Peace, Love & Acura
I have to say I'm wondering if it is the fuel delivery system. IAC, IMAP, BARO... If these sensors are failing, it will show up at startup. Does the computer display the CEL? Any codes?
Old Jan 31, 2006 | 09:55 PM
ajtcl's Avatar
Peace, Love & Acura
Before checking that, when is the last time the fuel filter was changed?
Old Jan 31, 2006 | 11:11 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
got my ngk iridiums on ebay
Old Feb 1, 2006 | 12:18 AM
Smalls's Avatar
Insert Sarcasm Here
are you serious?
I've never heard that before. It's hard to believe that plugs will go bad in 6 months.
Old Feb 1, 2006 | 12:28 AM
Cocoa's Avatar
2600lb CL
Sounds like the Idle Air Control Valve. It's located right under the throttle body. Or it could be the Alternator. I know they are two completely different components with completely different purposes. But with the little info I got, that's all I can come up with. Hope this helps.
The reason why I mentioned those two components, was because I had both go bad on me, and both had similar effects with the car.
Old Feb 1, 2006 | 08:40 AM
(Mid-Atlantic)
I hope you're just messin with him
Old Feb 1, 2006 | 10:19 AM
ib_jimmy's Avatar
make sure the throttle body is clean.
change out the fuel filter.
IMO
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
