What oil do you use?
Hey I was wondering what oil you all use.
My car has developed a lower engine knock and I'm curious as to switch to a thicker oil to remedy it. Currently I run Castrol 5w-30 dino on a 2.2 CL with 160k on the clock.
If you have a constant lower engine crank/rod knock, you will need service soon. No oil will long stop the knock from getting worse. The knock is the rod hitting the crank (and bearing) w/ force. Wear accelerates and at some point the connecting rod may fail leading to engine block damage.
A rod knock is a deep unmistakable, clonk, clonk, clonk. Most have heard this after an oil change on engine startup. Before oil pressure rises, their may be a knock or two until the oil reaches the bearings.
Higher pitched knocks may be loose piston wrist pin, valves, camshaft damage, etc.
good luck
good luck
Using Amsoil Synthetic 0w-30.
I agree with TexasHonda, you should fix the problem instead of putting a band-aid on it. This way you can fix the isolated problem before it starts damaging other parts of the engine. More repair = More money + More Time.
Originally Posted by CBloc-CL
I just switch from havoline Syn 5W-30 to Mobil 1 10W-30, and already I can tell the differnce, my engine is so much quieter. *99 2.3 CL 86,651 Miles*
Originally Posted by 98 CL
i meant using mobil one non-synthetic for being cheap. Synthetic is too fucking spendy
like the clean 7500 works for me
Any oil filter is probably good for two oil changes.. I am skeptical of the new expensive ones that keep cropping up.
Originally Posted by 97Acura3.0CL
5w 30 full synthetic
also a mobil one top of the line filter, I have read that you can use it up to 2 oil changes
Originally Posted by STL+3.0CL
Are any of you guys switching depending on the season? I just started switching to 10w -30 in the summer and 5 -30 in the winter. Does any one else do this?
I have had a couple of reputable mechanics say that using a thicker oil helps lessen oil burning/use with an older car. Only reason I have 5W30 is because I may be facing -25 deg. C. cold starts three months from now. Block heater will help with that though for those in cold climes. For protecting your engine upon startup I think 10W would be superior especially when it's hot. I think the W20 oil grade Ford calls for now is a load of crap, it's just so they can claim slightly higher fuel economy ratings on some of their cars.
Originally Posted by PimpCL23
has anyone changed the weight of the oil due to their mileage yet??? cause i see a lot of 5w-30's still being used
OK since im searching and dont wanna create a new thread and be accused of not searching. . . really I just dont wanna be on the recieving end of one of BlackAck's noob pics
anyways, how are those out there running on oils other than 5W-30 going, I see some 10Ws and some 20Ws
. . . anybody run 0W oils???
I wasthinking on running 5W-40 instead of te regular 5W-30 and 10W-30s ive used in the past. . . but seeing as how im in wonderful Texas, and summer is here, I might try out the 20W as some of you have. . . SPEAK UP people. . . lemme know
im currently running Motul 300V 5W-30, straight up race oil. . . I looked into Eneos like that other guy mentioned, and I found a source where I can get it cheaper than what im paying for Motul right now. . . Eneos also only has 0 and 5 weights available
. . . anybody run 0W oils???I wasthinking on running 5W-40 instead of te regular 5W-30 and 10W-30s ive used in the past. . . but seeing as how im in wonderful Texas, and summer is here, I might try out the 20W as some of you have. . . SPEAK UP people. . . lemme know
I'll spare you this time though. I run 5W-40 delvac for diesel and truck engines. Runs great, I love that weight for some reason.
1st number is the weight, 2nd number is the viscosity index. . . the lower weight oils help with colder starts and fuel economy, higher weights tend to be better lubrication at temp. . . the viscosity number at the end also more or less tells you how well it does at temp
IBankMouse
Jun 13, 2020 12:53 PM
