What is OBDII code # 22?
Old Aug 12, 2002 | 01:33 PM
jttoombs's Avatar
The Human Radar Detector
Just used the paper clip trick to get the read out from my check engine light, and I refrenced it against niedejb's website, but I couldn't find it. So if any body knows the codes please help.
Old Aug 12, 2002 | 01:59 PM
q2slinger's Avatar
I think that is a four digit code. The four digit codes don't have a two digit equivelant for the paperclip thing. I had that same check engine code myself. I just reset the ecu and it never happened again.
Old Aug 12, 2002 | 02:27 PM
jttoombs's Avatar
It was a four flash sequence code. It was two long flashes and two mini flashes. From what I understand its 10 for every long flash and one for every short flash. So L+L+S+S = 22
Old Aug 12, 2002 | 04:57 PM
pianoman41's Avatar
All the OBDII codes are 4-digit (P+4). If you can get the 4-digit code I can tell you what it is on my scan tool.
Old Aug 12, 2002 | 05:34 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Only the scan tool gives you the 4 digits.
The cel flashing 2 digit (does do multiple 2 digit codes but no four)has an equivelant four digit.
Old Sep 1, 2003 | 05:24 AM
whittles's Avatar
I 2 have this code pop up and I can not find what the code is. jttoombs have you found the correct info?
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
