What The Hell Is Wrong With My Cl?
Old Aug 22, 2004 | 02:29 PM
CL-'s Avatar
CL-
Three - Point - OH
Well, the car doesn't stay stared..... unless the battery is powering the plugs and other stuff as soon as the battery dies out the car shuts off
OK. so w/ that in mind.. We all can agree that the alternator is bad.. so I changed it..
Got 1 from autozone and replaced it
But the problems is still there?
what could be wrong with my car?
Someone help.. is there a fuse that i should look into or what?
Old Aug 22, 2004 | 03:05 PM
khobbz's Avatar
recall on ignition switch!!
Old Aug 22, 2004 | 06:47 PM
CL-'s Avatar
CL-
Three - Point - OH
Nah the car starts perfectly with the battery but then alternator isn't working.. It provides power to the whole car once its moving by the belt.. but its not.. i wonder if the new altanator is bad or something is wrong from the fuse box or the relay
Old Aug 23, 2004 | 09:58 AM
Hobo's Avatar
Flap.
does the "battery" light come on?
check the fuses. make sure the alternator was installled properly.
Old Aug 23, 2004 | 11:48 AM
legendaryCL98's Avatar
'07 November = STI
yeah.. probably the alternator wasnt installed right.. try asking someone at pepboys.. or the place u bought your alternator from..
Old Aug 23, 2004 | 12:36 PM
CL-'s Avatar
CL-
Three - Point - OH
the the alternator was installed right...( check and everthing) the battery sign is on.. which is the fuse for the alternator?
Is it a regular 15A fuse?
Old Aug 23, 2004 | 08:31 PM
CL2.3-Amature's Avatar
Look out ladies
Sometimes you can get a bad alternator. Is it a refurbished alternator or new?
Old Aug 23, 2004 | 10:11 PM
ad758's Avatar
Check the "Main Relay". Mine's doing simular. Start the car, as long as the key is in the start position, the motor runs. Let it go back to run, the motor dies. Mine is sporatic right now, so I'm going to check it (seems there are soldering issues from Honda). I found this on Civic SI site. they have instructions on how to fix the problem without buying a new relay.
Don't know that this is the problem, but sounds very familiar.
Old Aug 24, 2004 | 01:04 AM
ad758's Avatar
I need to re-phrase the last post. It's Club-SI, not Civic SI.
Old Aug 24, 2004 | 06:49 AM
lnsyone's Avatar
CL 4 LYFE
youll need to replace the headlight fluid and the exhaust bearing.
Old Aug 24, 2004 | 10:13 AM
nicholbr's Avatar
ttimberlak443
21
Oct 22, 2016 10:23 PM
datadr
Mar 23, 2016 01:39 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
DerrickW
Nov 15, 2015 05:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
