what the hELL!?!
what the hELL!?!
aiight tonight i was driving around for about a hour and 1/2, then i come home turn off car set alarm...Then i hear something going...I step beside my hood and my car was still running! Then it turned off like after 1-2minutes... What the hell is this?
My engine did something similiar to that acutally...I would take the key out of the ignition and the engine would continue to run. Turns out the CL has some recall in the ignition; the wires start to burn/melt away in there somehow. You might want to ask Acura about it. They fixed mine for free because it's under a recall.
(I'm not sure which years it was for)
Hope this helps man
Hope this helps man
Work safe avatar bish :D
Mine did the same thing. I was kind of embarrased cuz i was riding with some and they asked me if i was going to turn the car off or not? I checked to make sure i didnt leave the keys in again, but I opened to hood and it turns out it was just the fan running.
i want a bimmer =(
DamnThisHobby'sExpensive!
i thought the fan woudnt run if the keys were out and the car was off??? ive turned my car off in park and then turned the key a 1/2 turn so i could listen to the radio and the fan was off ans once i turned the key 1/2 way, the fan turned back on...
soo i thought the fan woudnt run without the keys in??
Still trolling
Fan will run to try and cool the engine down when real hot. Also, the fan will engage without the engine running when you turn the key on and the AC is on. The car defaults one of the fans (there are two) on to keep the engine cooler under the stress of the compressor.
soo is it bad if it comes on after? engine too hot? i only drove for like a hour and had the car running for like 20 min after while jamming music... never seen it do it b4
Gimmie my points Biatch!
Re: what the hELL!?!
Mine did that once after getting my 90k tune-up ( timing belt, coolant system flush, all new belts, valve adjustment, etc.) It turned out that my radiator was not full to hte VERY VERY top. The Temp needle would jump all over the place and look as if it was overheating. I topped off the radiator and the problem went away.
ya i guess it was just the fan from having it running for awhile... but ne wayz i think i should still clean injectors... i never had since i had my car... Are those ones you poor in your gas tank good? Which one should i use?
The only one that would be helpful is going to have the inject cleaned thru non chemical methods which honda/acura dealerships have and to change ur fuel filter. I forgot what the service is called but it cost like 100 bucks, i am sure if you ask they will know. They attach a machine or something and it cleans it. Majority of the time most cars won't have a serious enough problem to need their injectors cleaned. You can tell if you are idling like crap and mileage is poor. But if you one of those people that want the car in top performance then watever floats your boat and have it done every 50,000 miles. I will try to find out wat the process is called. I probably do a google search and find out.
Hey rodxx,
Had the same problem, bewildered the hell out of me. Bro, most likely it's just the radiator. If anything needs to be done just have the radiator flushed and refilled. This should solve your problem. Just like Aaron1017 suggested.
Hey Aaron, should have that file ready for you in a day or two. Haven't used the program for awhile so just trying to locate all the disks and stuff.
-Peace
-Peace
Originally posted by athlonxp
Hey rodxx,
-Peace
Hey rodxx,
-Peace
i do a fuel injector cleaner about every 6000 miles...i just go to auto zone and get like a pensoil or other major brand fuel injector cleaner and i'll usaully fill the car up with 89 octane instead of the 87 i usaully put in...is my system of cleaning the injectors actually hurting more than helping??? am i doing somethin wrong??
its paid for
its been said many times, but yeah it was your fan. my 2.2 did it all the time this summer, even if i just ran accross town with the AC on. It just runs to cool down the coolant and the engine, its no big deal.
Former Sponsor
It's da FAN
Hey Chris and Folks....!!
Check it out. I had a buddy with a Civic like mine install his own version of the Nology Power Core. For those who don't know... It's a capacitor for your ignition. But there's a bit more to it than just a capacitor. So he rolls to the local electronics shop and picks up a bag of small caps. He wire's this thing up like Nology shows. Then he's going nuts cause his car still runs for about 10 seconds after the key is out. His ignition system was still juiced until it ran the cap dry. I told him to diode the wire he tapped into so it didn't backfeed his whole system.
But. Yeah. Dude it's the fan. Don't fret. Just be happy that it works. My Civic's fan has been dead for a year. I had to rig up a new deal so it would come on.... When I tell it too ofcourse.
heheheh ok its the fan!! thankz though
Just weird after a year of owning my ride never seen that happen or actually hear it happen...
And what are you doing to your Project Car?
Former Sponsor
Project Car
I'm trying to make the CL as fast and handle as well as the Civic. So far I've only done some minor shit. I gutted the airbox pieces from the fender. Painted all four calipers red to match the car. Scrapped the "3.0" and "ACURA" emblems from the rear. Moved the front plate into the grill That looks sweet!! And that's about it. I don't drive it much. The Civic gets way more attention.
Former Sponsor
I regret to admit that I don't yet own a digital cam. However..... I will borrow one for a day to get some pics of my two kids. (Civic and CL) I moved the plate on the Civic about 3 years ago. It almost looks like Bugs Bunny from the front. It's amazing how many comments you get from this easy mod. It makes the car look so much more aggressive. You folks will dig it. I promise. Give me a day to get these pics up. Should I start a new post or tag it on this one?
08_UA7_Gr33k
02-11-2016 02:17 PM
DerrickW
11-15-2015 05:52 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
