wha gas do you use in your cl?
Old 09-28-2003, 04:48 PM
pmp93cl's Avatar
i'm just wondering what kind of gas yall use in your cl's. i got a 97 cl 3.0 and i use regular but i read somewhere someone said your suppose to use premium so just wondering what everyone else uses.
Old 09-28-2003, 04:51 PM
18anatak's Avatar
in my 2.2 i use 89 octane
Old 09-28-2003, 04:54 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
87 all the way. anything higher will just take longer to burn off and cause you to lose hp.
Old 09-28-2003, 05:09 PM
truraysa's Avatar
i use reg on my 98 3.0. oo and only at 76
Old 09-28-2003, 05:10 PM
Well, I dunno...
fizzle's Avatar
76 Octane? Sounds a litle low... I use 88 becuase the low grade here is 85...
Old 09-28-2003, 05:14 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
i think he is talikin about 76 brand gasoline.
Old 09-28-2003, 05:24 PM
Stapler's Avatar
official somthing of nascar.
I use 87
Old 09-28-2003, 05:49 PM
jorgev's Avatar
well i got lots of miles...on my 2.2 so i use premium ... i get more milage... i drive highways 38 miles to work 38 back... not counting going to school... so when i fill up (at the red E line) i reset my odo to 0 from 360+
the new MDX gets mid-grade... it rides the same and get the same milage than when i use premium
Old 09-28-2003, 06:24 PM
matteichenfels's Avatar
If you read the owners manual it says car will run best on 87
Old 09-28-2003, 06:47 PM
DamnThisHobby'sExpensive!
Acura3.0CL's Avatar
87....do a search...this has been talked about for a while before...
Old 09-28-2003, 07:01 PM
1999 CL3.0
dragon084's Avatar
i use 89 on a lincoln continental (1989 model)
can i be saving gas money by using 87?????
Old 09-28-2003, 07:06 PM
Stapler's Avatar
also check the manual on that lincoln i would say probably. I have a ford 429 that runs on 87, but its not the same engine so ... it would be good to check.
Old 09-28-2003, 07:09 PM
kevin79925's Avatar
93 octane Shell Gas..... $1.53 a gallon.
Old 09-28-2003, 07:10 PM
1999 CL3.0
dragon084's Avatar
dont get that started again
some people pay rediculous amounts for gas
Old 09-28-2003, 07:46 PM
dennis's Avatar
2 bucks here for 87.
Old 09-28-2003, 09:27 PM
I R 1337?
d00g's Avatar
Premium, i realized i get better milage so it kidna evens out... pay more go farhter pay less drive less...
Old 09-28-2003, 09:59 PM
'07 November = STI
legendaryCL98's Avatar
i use 87 at SHELL or CHEVRON only! because everywhere else uses 10% ethanol in there gasoline making it burn off faster, THAT sux0rs!
Old 09-29-2003, 05:38 AM
Homeless
chef chris's Avatar
Sunoco 94 ONLY!!!
Old 09-29-2003, 06:17 AM
PhilCL23's Avatar
chevron 94! gets better gas milage and my car runs smoother. also it's cleaner burning so it wont pollute the ozone.
Old 09-29-2003, 06:39 AM
teh Senior Instigator
CLpower's Avatar
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
it has been dyno proven that running anything higher then 87 on a 3.0 will make you lose a good amount of power. It will also clog up your injectors, and cause buildup because the car is simply not setup to burn anything higher then 87.
Do a search, this has been discussed many times
Old 09-29-2003, 07:19 AM
swclown's Avatar
Old 09-29-2003, 07:30 AM
Cause stock sux.
JLai's Avatar
Nothing but 93 octane.
Old 09-29-2003, 07:33 AM
CLpower's Avatar
your loss :P
Old 09-29-2003, 07:53 AM
Trailblazer = SUCK
LCARUCA 97's Avatar
only just recently have i been usuing 93
Old 09-29-2003, 08:25 AM
r3mix3r's Avatar
87 OCTANE.
Old 09-29-2003, 09:06 AM
Cause stock sux.
JLai's Avatar
your loss :P
My car's gain.
Old 09-29-2003, 09:25 AM
Big Block DOHC Type-R
Mark Davison's Avatar
Damn, I wish I could get 94 Octane! Most So. Cali. gas stations only have 91. My H22 has 11:1 compression, I cant run any less. I run octane boost 2-3 times a week. When I drive my car just out of state, (Arizona, Nevada) they got 105 octane. All the V8 boats out there use it. I'll fuckin fill right up with that stuff. My car loves it!
Old 09-29-2003, 09:57 AM
CLpower's Avatar
My car's gain.
how do you figure? You have a 3.0 right?
Old 09-29-2003, 10:43 AM
No, not v6, H22, it's a 4 banger. Most H22's are 10:1 or 10.5:1 I'm not sure but since mines type-R, It's 11:1. All type-R motors are 11:1.
Old 09-29-2003, 11:38 AM
clracer97's Avatar
i feel my car runs better on 93 but i dunno it just seems weird usin cheap gas on such a good car!
Old 09-29-2003, 11:41 AM
CLpower's Avatar
type of gas has nothing to do w/ the car and everything to do w/ the motor
Old 09-29-2003, 12:36 PM
Cause stock sux.
JLai's Avatar
Supposedly, if you take an engine apart thats run 87 octane all its life...Then look at one thats run nothing but 93, the difference is night and day. I'm all about making this car run without flawless. I hate fixing shit.
Old 09-29-2003, 01:04 PM
A-CL Totaled Member
xrunner86x's Avatar
I use 87 usually from Exxon or Citgo. I found out why the cheapo gas station near me was so cheap, their regular was rated 85 instead of 87, my car didnt like it. Once I get new injectors and the turbo installed it'll be 91+ all the way.
Old 09-29-2003, 01:51 PM
TEAM BLUR So. CAL
TeamBlurryCL's Avatar
87 octane. you car will run alot smoother. . . trust me. it's great. or you can believe the urban myth that the higher octane, the better. it really depends on your compression ratio.
i do have a question though. it might me stupid but at least i'd get an answer:
most of us run 87 because of our cars low compression ratio 8:8:1. but since most of us have e/h/i wouldn't that raise our compression ratio? turbo cars have to run high octane because of the forced induction; but with an intake we are taking more air in than stock, so wouldn't that raise our compression ratio signifcantly? shouldn't we use a higher octane may-be 89?
Old 09-29-2003, 02:25 PM
swclown's Avatar
the stock ecu can accomadate and adapt to the additional air from an intake, but the FORCED amount of air under pressure from a turbo is WAY too much.
Old 09-29-2003, 03:22 PM
woodek's Avatar
Used 93 oct. in my 98 3.0 for 6 months. Went to 87 oct. and couldn't believe how much better my car ran (on top of saving $$).
Old 09-29-2003, 03:47 PM
CLpower's Avatar
not true at all, oil would have a bigger effect on engine life ( I run synthetics only), not gas.
Old 09-29-2003, 04:45 PM
Cause stock sux.
JLai's Avatar
I read that somewhere...I think it might have been on here from a long long time ago.
I know our cars aren't turbo, but think about it this way...If it was, higher octane helps prevent detonation. So I figure it must just burn cleaner in general...Which would therefore be better for my car.
Anyways, it might not even make a difference with our cars. Any wanna go dyno test for us?
I use full synthetic too. :P
Old 09-29-2003, 05:28 PM
CLpower's Avatar
it's already been dynotested, car and driver did back to back dynos w/ 91, 89, 87 and gained 10 HP w/ 87 over 91
Our cars aren't setup to burn that high of octane fast enough so all it does is cause buildup
Old 09-29-2003, 05:47 PM
Cause stock sux.
JLai's Avatar
Hummm...Maybe thats why I'm running so damned rich. I puff out black smoke sometimes when I get on it.
Quick Reply: wha gas do you use in your cl?
