Warning for potential buyers of the silver-faced reverse indiglos.
Midnight Marauder
I got mine and installed them. They were straighforward until I went to screw in the two small screws in each face. Then I discovered that the pre-cutout holes were in the wrong place on the indiglos!! They were about a 1/8th of an inch off. So since I bought them on Ebay I had to make do and i helped "move" the hole to fit. I am pissed... but i got it to work.
Also, for anyone else installing indiglo guages:
Tap your red wire into the Red with Black Stripe wire off of the factory dimmer. The other Red with Silver dots is not the right wire. It will work but it will be in reverse.
Peace.
Peace.
Old School Ridin Clean
yeah that happened to me. Use double sided tape and stick on that way....very easy
Did u have any problems with your needles not working(not being able to read your car stats)
i have that problem i trying to figure out why
Midnight Marauder
What do you mean not working? Mine move and I didn't break any (luckily). They work just like normal.
Or are you talking about not being able to see then because of no light? I left the top two bulbs in so that they dimly light up the face of the guages but I'm going to put some blue or red film in there so they shine red onto the guages instead of white light.
I wish I had some of the double stick tape with me cause i would have used it, Oh well, you have to look close to see my little messed up area and at night you can't see it.
Stage 1 Audi S5
I had the same problem with my gauges but its no big problem. Just had to adjust them alittle bit and i can bearly tell i did anything except when i look real close at night
As far as your guages not working, if they arent moving it is because you put the double sided tape under them. This made the face stick out and touch your needles which will stop them from moving
Mine had the spacing issue with the screw holes, but the worst part is they died after two days! Sometimes the flicker very dimmly but i don't know. All connections are good and there are no blown fuses. I think they look dope but I wouldn't recomend them.
fellow MASShole
anyone have any pics of these on or not on or both !! uve been debating if i should get them i think i like the white face reverse indiglos better tho ...
MaCe
MaCe
Stage 1 Audi S5
MaCe
MaCe
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
