venom 400
Old 07-06-2002 | 01:15 AM
jchavez's Avatar
venom 400
has anyone ever dyno tested their cl before and after getting a venom 400? It says up to 25% increase in horsepower, but how many horses do you really gain? is it worth the money?
Old 07-06-2002 | 01:16 AM
jchavez's Avatar
Re: venom 400
Could you please include whether you have a 2.2 2.3 or 3.0
Old 07-06-2002 | 03:25 AM
JLai's Avatar
Cause stock sux.
Its good for an auto cause it really helps with shifts when you're looking for trouble. I'd save my money if you already have a stick. If I had to do it all over again, I'd probably just spend the money on cosmetics. Can't make our cars go fast without smurf juice.
Old 07-06-2002 | 07:46 AM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
You dont need juice.
Old 07-06-2002 | 08:07 AM
Bartman's Avatar
One Large Member
I installed Dustbuster's Venom on my 3.0 last weekend.
So far, I like it. I have noticed some things though...
For instance, after I hooked it up......the LED was pretty much "ON" all the time. It's something like a game now to try to keep the light "OFF" as much as possible. This has required a slight change in my driving habits (maybe not a bad thing).
I definitely feel more low-end power. My tranny seems like it holds gears too long before it shifts though. It will peg at the redline....then hold.....then finally shift. I suspect I'm losing some power at the "hold"........doubt if that's a venom problem though.
Good thing for me so far
Old 07-06-2002 | 12:35 PM
jchavez's Avatar
thanks for the advice, I'll save a little more for some rims instead
Old 07-06-2002 | 02:58 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Check to see if the LED wire was installed correctly (or are you just hitting the gas hard all of the time? :P).
There's definitely a low-end power increase!
As for the "hold", It's always done that since I first installed it. I actually had to think for a minute to figure out what you were saying. I guess I just got used to it.
Old 07-06-2002 | 03:18 PM
chiggacl68's Avatar
speed freak
as for the led light always being on...its really how u press your foot on the gas, if wont go on if u just press on the gas...but if ur intentions are to floor it, the light will go on, its all a matter of knowing the point in which the venom turns on.
second the hold or watever, it is more likely that the auto tranny in cl's is like that. i have two friends with cl's both auto, and their cars already do that hold.
the venom i noticed performs best in spots in where the engine seems to stop pulling hard, the venom keeps the power goin when the engine would stop pulling as hard.
Old 07-06-2002 | 07:03 PM
Bartman's Avatar
One Large Member
The Venom is working fine....my foot is just too heavy (hence, the light coming on as I leave every stoplight.....stopsign......on-ramp........off-ramp...... )
I finally found a suitable home for the LED.....I put a 1/4" hole just to the left of the "interior light control". Right on that 45 degree (or so) break between the vertical surface and the horizontal.
So far, I LOVE it!
Dust - I'm glad I caught the post where a guy was asking about re-programming a Venom......and you said you wanted to get rid of yours. I doubt I could buy a nicer "used" unit!
Old 07-06-2002 | 09:15 PM
You're welcome!
I'm glad you like it!
It served me well, but since I installed nitrous, the Venom just sat in my car in the "off" position (collecting dust)!
Enjoy!
Old 07-07-2002 | 12:04 PM
krayzracer's Avatar
venom 400
One thing about the venom from personal experience. Don't use it if you don't have to. There is an on/off switch for a reason. So only turn it on when necessary. I had mine for about 6 months and my tranny started slipping. And mine was alwas on. So try to be careful on how much u use it. Cause i have to get a new tranny. But thank got for that exteded warrenty. Also....does anyone with the venom have problems with it blowing there secondary O2 sensor??
Old 07-07-2002 | 01:46 PM
JLai's Avatar
Cause stock sux.
Re: venom 400
Are you sure that was caused by Venom? I've never heard of anyone elses doing that.
Old 07-07-2002 | 06:50 PM
krayzracer's Avatar
venom 400
i'm almost positive it was from the venom because u know how it shifts hard if it is engauged but u don't floor it all the way?? or does that only happen to mine??
Old 07-07-2002 | 07:52 PM
I ran mine ON every day for over a year! No problems!
Old 07-07-2002 | 08:00 PM
krayzracer's Avatar
venom 400
i guess i got a lemon. lolz. whatdo u run in the quarter mile??
Old 07-07-2002 | 08:04 PM
Re: venom 400
With the Venom 400 on, no faster than with it off: 15.85. I no longer have my Venom. I sold it (can't run it with nitrous).
Right now (if that's what you're asking), my best guestimate is about 14.2/14.3. I have not been to the track with the 75-shot in. I'm basing my guestimate on the cars that I'm beating on the street!
BoricuaTL
04-08-2016 01:08 PM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
InFaMouSLink
10-30-2015 09:43 AM
xsilverhawkx
09-28-2015 06:51 PM
kocyk123
09-22-2015 11:12 PM
Quick Reply: venom 400
